Question about Garden
Linkage bar under seat emergency shut off - Garden
  • 513 Answers
What about it there is one e-mail me wade at wadembly@aol.com if i can help further
Posted on Jun 28, 2009
Where are the spare wheels kept in a Hyundai terracan looking the bar for releasing spare wheel
The bar to lower the spare wheel is located under the back seat. The back seat is a 60/40 split seat and the bar is under the 60 longer seat. You need to pull the lever at the top of the seat near the head rest and lean it forward as far as it will go and then pull another lever at the base of the seat facing the door, Then lean that part of the seat forward to reveal the spare wheel lowering bar sitting in 2 clips. Take that bar to the back of the car and lift the tailgate. Just to the right of the latch that locks the tailgate in place is a hole to suit the bar. slide the bar all the way home and use the tyre lever to wind (anti clockwise)the spare wheel down. You're welcome.
May 19, 2017 | Hyundai Cars & Trucks
My battery is dead in my Saab 9-3, I want to manually open the trunk.
if the battery is completely dead... there is a way to open the trunk from the inside. it involves putting the rear seat down. in the middle under the back window theres an emergency rear seat release. lower the seat, and then pull emergency trunk release on the top of the trunk door. hope this helped.
Aug 03, 2016 | Saab Cars & Trucks
I have a 2000 Nissan frontier it is stuck in drive even in park it seem like it is still in drive
Correct, the clip that holds the shifter linkage to the transmission fell off on my 2000 frontier due to rust. Before getting under truck block up wheels and engage emergency brake. I crept under the truck wearing saftey goggles because of loose rust and debris, from the passenger side and looked up and there is was, the linkage was separated from post on transmission. You can easily put linkage back on but you will need a clip to hold it in place, it is not unlike the clips on the door lock cams. Add the clip and you are good to go.
Feb 16, 2015 | 2000 Nissan Frontier
Vehicle will not come out ofpark with engine running
does it come out of park shut off?? if not...then you have a linkage problem...did ya happen to run over someone or something recently to damage the connections for linkage arms under the car? check that otherwise the problem is in the column. Or...console..whichever.
Mar 18, 2014 | Cosco Juvenile Highback Booster Seat,...
I need to replace my rear sway bar endlink bushings to pass inspection. any directions/assistance?
(Caution ) sway bar end is under pressure.
1.go to AutoZone get new linkage bars or just the bushings depends on wether the bar has grooves wore into them from use and new nuts. 2. Raise and safely support vehicle,3. remove tire, 4.using floor jack safely support the lower suspension arm and raise to remove pressure on the linkage bar between swaybar end and lower arm 5. remove the nut under the lower suspension arm that retains the swaybar linkage ,6. loosen and remove nut at swaybar end. 7.at this time only lower the lower suspension arm enough to remove the linkage bar. install new bushings or bar to the swaybar end don't completely tighten nut at this time.8. install new lower bushing then jack the lower suspension arm back up aligning the lower end of the linkage with the hole in the arm once pressure is lifting the swaybar install the lower nut and tighten at this time Torque top nut to35-47 Ft lb and bottom nut 8-10- Ft lb lower the jack from under the lower arm and install tire lower vehicle ready to go Appx 1 Hr per side
Feb 20, 2010 | 1996 Ford Thunderbird LX
Won't shift when taking off intell you let off the gas.
Check/follow cables running from throttle linkage for seized at, or to, transmission linkage. Lube them up good and make sure all move freely. Be sure to use all safety precautions while under there, such as emergency brake, in park, engine off, and block the wheels. It may help have someone, push accelerator (engine off) while your under there so you can see and understand how it works and where to lube.
Oct 08, 2009 | 1999 Dodge Ram
The front driver seat on 2004 Camry is stuck
Perhaps an item got caught under the seat and possibly affected the linkage wire between rail tracks.A small linkage wire trips the console side track.Without this,that particular track will not disengage.Look under the good working passenger side seat and you might notice this linkage wire.It will then give you an opportunity to see if it works well on the inop seat. You can pull that wire(or trip that linkage arm by hand if you are in a dilemma and need the seat moved in order to drive but use caution on these moving parts and dont get pinched.
Jul 27, 2009 | 1992 Toyota Camry V6
I can't get my convertible top to go up or down, it is stuck half way. Is there a manual release for it?
The convertible top motor and release lever are in the luggage compartment.
From the Bentley manual, the following general procedure is suggested in order to close the top in an emergency situation.
Main motor. To release the top linkage from the motor, lift the left corner of the rear seat to access emergency release handle.
It is then possible to push the top manually to a near closed position. In case of the semi-automatic top, simply attach and lock the front latches.
Front latches. Once the fully automatic convertible top has been released from the motor and manually pushed to near-closure, emergency latching of the top is possible by using the S-shaped hex key provided in the emergency tool kit(attached to the trunk lid underside).
First, remove the the plastic cover over the latch motor in the front bow of the convertible top.
Next, use the hex key from the tool box to crank the front latches shut.
May 12, 2009 | 1999 BMW 323 Series
Gas goes to carb. but not to injectors 1995 murcury Tracer
Replace the fuel pump relay switch under the drivers seat. And replace the fuel pump shut emergency fuel pump shut off switch. Should be located in rear of car in trunk area.
Mar 20, 2009 | 1995 Mercury Tracer
Popping sound front end
It is the Front Sway bar linkage.
Dealer item only at the moment. 63.00 each 135.00 with tax.
Replace the linkage and the problem will be solved.
Oct 19, 2008 | 2005 Dodge Dakota
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
