Question about Philips 19PFL3403D/27 19 in. LCD TV
Model 19PFL3403D/27 having trouble powering on the TV. Even after pressing the POWER button the the side of the TV and toggling from OFF to either STANDBY or ON. It should not be this difficult just to turn on a TV.
    President:
  • 1,077 Answers
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
    President:
  • Philips Master
  • 775 Answers
You may want to check this:
http://www.ebay.com/itm/715T2906-2-715T2906-3-POWER-PHILIPS-19PFL3403D-27-F7-REPAIR-SERVICE-/160722541238
Don't promise it's what you need, but it describes what issue does it address.
Hope this helps!
www.coppelltvrepair.com
Posted on Jan 26, 2012
I cannot find the place to connect power cord into the flat screen. I searched the book on line to go with the model number Philips 42pfl3603d/27 and it wasn't specific. The place where it showed is not...
I've never had this TV but from what I can find on the internet the power connector is either at mid bottom or mid top of the backside. As for the cable it should be shaped like an 8 with one half more box shape. My TV's power connecter is on the very bottom. Wish I could help you more, but without seeing this model this is all I am able to say. Good Luck.
Mar 20, 2014 | Philips 19PFL3403D/27 19 in. LCD TV
Where can I buy a power button
you can buy it from any eletronic spare part selling shops.
Oct 27, 2013 | Philips 19PFL3403D/27 19 in. LCD TV
I just bought a new 40 in. philips LCD television. I plugged the power cord into the tv then into the wall outlet. the tv will not turn on or make any sounds when trying to turn it on with remote and...
Hello, make sure power cord is pushed in all the way in to the tv. Also make sure you have power at your outlet. I know it sounds dumb, but I've seen people chase their tail for hours before coming to the conclusion that a circuit breaker was tripped. Make sure you have good batteries in the remote. If the TV has a power button on the tv, try turning it on there instead of the remote. You can check to see if there is an on/off switch in the back. Besides this it should be pretty straight forward. You might have a defective tv
Hope this helps
Thank you in advance for your feedback
Mar 04, 2011 | Philips 19PFL3403D/27 19 in. LCD TV
Tv will not turn on
If the LED lights up and turns green or stays red then you have a power supply problem
Dec 08, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Where can I obtain Power Supply for Phillips 19PFL3403D, since my unit has no power or standby light...???????
Check the power source?Yes,than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
19pfl3403d/f7 rolls constently thru the channels
If it does this, even when the remote control is in a different room (or has the batteries removed), you need to have the set serviced by a professional.
If it only happens when the remote is nearby then you may actually have stuck keys or the equivalent shorting inside the remote. Some remote cases open easily and you can blow out the inside and under the keys with "canned air" spray.
If the problem is with the remote, you can buy a cheap replacement at a local drug store. They will be labeled "universal" remote. However, no remote is truly universal. Check the label on the package and verify online that the device will work with your brand of TV BEFORE you buy.
Never open the case of a CRT or Plama television as there are LETHAL voltages inside for WEEKS after the set is unplugged.
Jan 02, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Closed Caption won't turn off
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
Aug 11, 2008 | Sanyo DS31520 31" TV
Philips 19PFL3403D/27 19 in. LCD TV Logo
842 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
