Question about Dryers
Whirpool dryer trips breaker but not every time.
2 year old whirpool dryer trips breaker but not every time it is used. An electrician tested various parts of dryer with varying results. At first he stated we had a bad heating element. The element was taken to an appliance parts store, tested, and declared okay. Our electrician friend came out again and tested various parts on the dryer and could find nothing wrong.
    President:
  • 3,113 Answers
Try a new breaker.
Posted on Jun 27, 2009
Our glass top range quit last night. The breaker threw and when reset, it snaps. All 4 burners, lights, etc not working.
any electrician knows that besides a short activating a breaker , items such as leaking insulation , moisture , or control unit problems will trip a breaker
so get in an electrician to test everything
Jul 05, 2017 | Dryers
When we start the dryer the gfi trips. i have looked under the dryer and see no loose or broken wires
Could be your dryer breaker isn't big enough in terms of gfi use. If we use our washer with any other appliance, we trip the breaker, it's the wiring to the breaker box, the breaker can't support that much use, you might need to upgrade your breaker or wire it differently. Call an electrician to do it, if you mess up, you'll electrify yourself. Wow that was an old question, doesn't anyone use this site?
Jun 14, 2015 | Washing Machines
Spa blower trips gfi
call an electrician to do an insulation check
insulation will eventually break down under ground normally from ants eating it
Mar 09, 2017 | Pool & Spa
My civ60 tumble dryer gets hot for 10min then trips main switch
see the possible causes:
1) Unplugg the dryer from the wall, if the c.breaker of your house trips, the problem is in your house.
2) Connect again, and plugged the dryer, if the c.breaker the problem is some component attached to the dryer, a) Test for shorT in coil b) POWER CORD test for short c) Test the main motor for short and replace,d) Test any other devices, such timer, switch or some wires making contact with the chassis. or you must call some experimented electrician for to isolate the short circuit. God bless you see the diagram attached.
Jun 09, 2012 | Dryers
NO Heat
Replace the timer,the spot on the timer is burned out.
Oct 01, 2009 | Whirlpool LER5636P Electric Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
Electrican Question - For a School Paper Not a Real Scenario
In my opinion turning on circuit breaker first is ok. First to determine what is tripping the breaker. Isolate what is on that circuit. There are always different ways of troubleshooting.
Mar 23, 2008 | Heating & Cooling
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
