Question about Moen & One Handle Tub & Shower Faucet
I need to take the handle off of the Moen T2442 Shower faucet. What tool do I need since the handle seems to be held on by a hex screw but I can't see it to know for sure. I am trying to replace the Moen 1222 cartridge.
  • 39 Answers
It's a hex
Posted on Jun 29, 2009
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
Moen shower handle hex screw stripped, will not come out
hi mike:) do you mean the tiny little hex bolt which holds the tubspout in place or the handle?
Jul 31, 2011 | Moen & One Handle Tub & Shower Faucet
We have a moen legend 3175 one handle with pressure balancing valve. how do you get the handle off
There is a hex head allen screw on the underside of the handle. Loosen it and gently pull out on handle while tapping on handle body with non-marring tool Thank you.
Dec 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The handle seems to be loose because there is a lot of play in the handle befor the stem ingages . Is this normal in the handle
If it's the one I'm thinking of, remove cap in center, and remove Philips screw, and pull handle off. If you have the hex shaped piece still on the stem, look at underside for an Allen key, set screw and tighten it, and put handle back on.
Sep 30, 2010 | Moen & Posi-Temp Single Handle Shower Or...
My handle is loose but I cannot find a tool that will fit the set screw. What is it, what size. Blade screw, Phillips Screw, Hex, torx, what? Moen T2442 single handle shower diverter.
It would be an allen wrench. Any typical multi sized wrench should have the proper sized allen wrench.
The holes can often become filled with grime so be sure to seat the wrench properly to prevent stripping.
Aug 07, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Posi-Temp Shower Handle removal
I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
How do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
628 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
