Question about NetGear WGR614 Wireless Router
How do i connect netgear wireless router to att modem for my laptop?
  • 34 Answers
First you connect the att modem to the back of the router. The RJ45 (Wider than a phone connector) connects from the modem out to the port on the router that is spaced away from the others.
Second you have to connect a cable from your laptop or computer to one of the other ports on the router. This is only for setup and won't be required after that.
Once connections have been made and router and modem are rebooted, open a browser (IE or Mozilla) and let it time out. then in the address bar typ 192.168.1.1. You should then see a pop up box asking for password and user name. The default user is "admin" without the quotes, and the pass is password .
This will now open the setup boxes. Change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
Change SSID from default NETGEAR to any desired name (for e.g. Home)
Select the Region as applicable - Incorrect selection may cause performance problems.
Select any one of the available Channel.
Click on either WEP or WPA (Preferred) security. A box will open for a passphrase. REMEMBER what you put here. this is your security key! If you pick WEP you will need to write down the 10 digit key.
Apply the changes
Now you can close the router setup and disconnect the computer from the router. You should now see a box on the systray that says new wireless networks available. Click it and you should see whatever you named your network. Click it, and then the connect button on the bottom. It will then say identifying network, and eventually will aske for the key. This is the numbers or pasphrase if WPA.
You are then conncted to the router and it should be connected to the internet., If not just ask and I will go through that setup for you.
Please rate this if you wouldn't mind
Posted on Jun 28, 2009
Find compatible router
Contact Netgear! Their tech. support number should be in the documentation that came with your router.
May 15, 2017 | Motorola Computers & Internet
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
I purchased the AT&T Motorola modem if I connect my desktop directly it works, but my laptops do not - if I connect my Netgear router my laptops then work but my desktop does not...help...
>in order for you not to have more problems at all
>first, ask AT&T to set your motorola modem to BRIDGED MODE first
>then, connect your Netgear router to the modem
>connect the desktop computer to the router and check you connection
>after you got the desktop computer connected to the internet
>try to establish connection to your wireless network using your laptops (Laptops cannot connect to Motorola modem since it doesn't have wireless capability like routers)
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | NetGear RangeMax WPN824 Router
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Aug 30, 2009 | NetGear RangeMax WPN824 Router
NetGear WGR614 Wireless Router Logo
218 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
