Question about SanDisk Sansa c200 MP3 Player
Not charging sandisk 1.0gb mp3 does not show it is charging when hooked up to laptop to charge does not chage have 3 of them none of them will recharge am i doing something wrong no instructions when I bought them thank u
Me too tell me if you know plzzzzz thank you but when im know how i tell it to you
Posted on Aug 04, 2009
Change battery sansa ciip
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 13, 2013 | SanDisk Sansa Clip MP3 Player
Battery not holding charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 26, 2013 | SanDisk Sansa e250 MP3 Player
Sandisk mp3 not resonding or holding charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jun 27, 2012 | Audio Players & Recorders
I believe the mp3 player's charge to last for 15 hours. It is only holding a charge for about 5 hours
Ifthe recharageable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 26, 2011 | SanDisk Sansa Clip MP3 Player
It won't charge when I hook it up to do so, it used to but lately no matter what computer I use, it doesn't do anything
not sure but doesn't that model have non rechargable batteries in the back that need to be replaced? If they are rechargeable wouldn't you need the ac outlet to charge them?
Jan 28, 2010 | SanDisk Sansa e250 MP3 Player
Sandisk 2GB Sansa clip will not charge with USB.
The problem maybe the usb cord or it maybe the hardrive in the monitor hooked up to the network drive. If this doesent help i will try to help as much as possible.
May 22, 2009 | SanDisk Sansa Clip MP3 Player
Battery won't recharge on my sandisk clip anymore
my c140 mp3 player conect to the computer and then auto re start again & agin
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Wont charge
with your problem i first suggest callng sandisk and asking for advice before you go through all that trouble and money
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
Recharge
you probably have charged the battery when it wasn't empty and got a memory effect
Nov 12, 2007 | Samsung YP-U2X Digital Media Player
SanDisk Sansa  c200 MP3 Player Logo
139 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
