Question about Dremel Variable - Speed Multipro Rotary Tool 395
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
    Problem Solver:
  • 5 Answers
Remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Posted on Aug 31, 2010
You get on the Dremel web site and send them an email indicating they better wake up the engineer who designed this and the engineering manager who let this go out. That plastic pc inside holding the collet nut while turning with the wrench is called "planned obsolesence (sp). They need to add more meat to the shaft with a hex head so you can hold with 2 wrenchs and remove. That will eliminate stuck collets. Mine is sitting on the shelf stuck. I tried everything. I may be headed to Home Depot for a Roto Zip as that head works the way I described above!
Posted on Jul 02, 2010
  • 2,176 Answers
I generally tap LIGHTLY on the side to loosen it up any excess pounding will damage the collet and other parts.
Posted on Jun 28, 2009
John Rogers: your comment may have seemed obvious to you, but remember, when dealing with Dremel/Rotary tools, they're several of us females who like to think we are mechanically inclined. We just don't have enough experience to think of those priceless little pieces of advice. Thank you!
Posted on Apr 06, 2018
    Problem Solver:
  • 7 Answers
I know it's obvious, but how about soaking the nut in WD40?
Posted on Sep 03, 2014
I have dremel 4200 ezchange bit broke inside collet how do i take collet out
remove the collet nut
use pliers or the like and pull the collet from the shaft jaws
remove the broken bit
put the collet back in the jaws and refit the nut
Oct 22, 2016 | Dremel Tools & Hardware - Others
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
Want to put in new 1/4" collet cone.......how
Undo the collet nut then find something that you can get a firm grip on the old collet and pull it out. If this doesn't work and it is still stuck carefully try an eze- out to remove the old collet. Once you have removed the old collet just insert the new one and replace the nut.
Feb 11, 2011 | Makita GD0600 1/4 Inch Die Grinder With...
Bit wont tighten down in collet
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
Oct 19, 2010 | Hitachi M12V2 3Router
How do you change the collets on the Hitachi m12v2?
Matt, Remove the collet nut completely. The collet should come right out of the end of the motor shaft. Put the other collet in it's place and replace the same nut. I assume you are switching between 1/2 inch and 1/4 inch tools.
Aug 23, 2010 | Hitachi M12V2 3Router
Back in December 2009, I wrote asking why my Freud FT2000 router wouldn't release the router bit when the collet nut was loosened. "allstarbob" wrote and said to sandpaper the collet. That didn't make...
Thanks for the follow up....
I'm glad your problem was resolved in the end.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 10, 2010 | Freud FT2000E 3 Router
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
I have a Durabuilt rotary tool model S1J-FE2-10 that I can't seem to get to hold a bit. The directions say to hold the spindle lock button down and put the bit into the collet and tighten. I doesn't hold...
User Error! There are different diameter collets. I bet you are using a larger diameter bore collet than the bit outside diameter. Collet can be purchased at any hardware store. To remove unscrew nut, remove collet and replace with proper diameter.
Aug 28, 2009 | Tools & Hardware - Others
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
5,296 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
