Question about Bernina Activa 130
Thread breaking problem
I have a Bernina 1001 and I just recently serviced it. I am using the clear nylon thread for all my projects and sometimes my machine will break the thread and sometimes it will work fine for a while. When it breaks it, it seems to be pulling at the bottom somewhere because it breaks right at the needle. If I go really slow it wont break as much but you can hear the tension noise in the thread as it pulls the thread up through the fabric....it seems to be getting worse and the tension dial seems to do nothing.
  • joey20046 Jun 28, 2009
    Ok, so I watched underneath in the bobbin area as it was sewing and I slowed it down and turned it manually and saw that the thread gets caught on one of the grooves in that black thingy that revolves around the bobbin and it pulls it and that's what is creating the thread tension noise (like someone pulled a piece of thread as tight as they can and strummed it like a guitar, type noise...) Is there supposed to be a groove near the end of the black thing im talking about or is it supposed to be smooth? I was wondering if that part is called the hook that another post was talking about...
    Problem Solver:
  • 10 Answers
The problem is that the nylon thread will actually cut into the race cover and create groove, it should be smooth. The only way to correct this is to replace this cover. I can not stress enough do NOT use nylon thread on your sewing machines, it will do permanent damage and cost you 100s of dollars in repairs.
I have 25 years experience working on these machines and have seen this happen time after time.
Posted on Jun 30, 2009
I have a Bernina 350 SE. Trouble with buttonholes: thread accumulates in lumps intermittently. Stitches become very small, fabric stops advancing, thread piles up.
Have you tried re-threading the top thread? Sometimes the stitches get small and pull tightly because the thread is looped around a guide or the thread spool. Just a thought as that happens frequently with my machine.
Oct 19, 2017 | Bernina Sewing Machines
Intermittent sewing problems
You have two problems:
1) Sometime it sews fine, but other times it will sew like there is no tension on the thread and create a "birdsnest" in the bobbin compartment.
Cause : Threading the upper thread
- clean upper thread tensions discs
- do not forget "• raise the needle and presser foot" (see manual page 18)
2) Sometimes it just randomly changes ...
Please open new ticket. Give tu us more info. It seems like Short circuit on S-print, but your description is chaotic (not usable)
Apr 19, 2017 | Bernina Activa 130
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
My Bernina 1010 keeps breaking top thread. I've changed out the needle and thread...any tips?
the top thread tension may be to tight
the needle & thread may not be compatable--here's how to tell
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 07, 2010 | Bernina 1008
Bernina 2500DCET serger keeps breaking the centre needle thread for no apparent reason .Already had machine serviced,new needle plate didn't solve anything either. Any ideas
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Mar 01, 2009 | Bernina 2500DCET
Bernina Aurora 430
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
Jan 11, 2008 | Sewing Machines
Sewing Machines Logo
178 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
