Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Aquarius extra wd64 grinding sound + broken
Off and on grinding sound during wash cycle. 'Stage dial' needs help moving to the next stage. Eventually cycle stops and door unlocks with machine still with dirty water in it.
SOURCE:
  • 172 Answers
SOURCE: AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
Posted on May 10, 2008
barkencoa
  • 3463 Answers
SOURCE: prewash light on machine will not go into next mode wash ?
Check pump and filter for blockage.
Posted on Dec 14, 2008
tborn6
  • 700 Answers
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
Posted on Jan 06, 2009
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
  • 5 Answers
SOURCE: does my hotpoint washing machine aquarius wd64
if your hotpoint has no obvious filter ( small flap on front ) its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.
pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully andd make sure its all back together as before.
Not easy but the blocked filter causes so many hotpoint issues. Its a pain the way they have built it inside the machine rather than making it user friendly.
Posted on Sep 17, 2009
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My Hotpoint Aquarius WD 420 main control sticks.
If the water is not heating up, then this will stop it on, or not taking in water at some stage could have the same effect.
Dec 08, 2008 | Washing Machines
Hotpoint WD64 No power - help please !
hi from n/west uk from the symptoms you describe ? that you have no lights on machine? this is most definately total power loss to machine so if you are certain? the fuse is ok? next is has the wire/lead from plug chaffed or damaged breaking the supply? this next possibility may sound odd but the socket you plug machine into ? may be faulty ie the damp location at rear of machine could have caused deteriation of socket terminals or wires even the wire may have broken/come loose? have had this happen in homes and caused by wires not secured properly and eventually arcing/ resulting in power fail at socket ? may i suggest try another elec appliance ie lamp/hoover/ iron? to check if socket is operating just to eliminate? also if the socket is a fused type? make sure this fuse is ok too? finally have you checked consumer unit for possible seperately fused/trip out for the machine use socket ? hope this helps find fault best wishes
Oct 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
