Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
2010 BACKFIRING NOT STARTING
Tractor was running was last driven. Today it will not start and backfires thru the muffler.
Sounds like bad gas
Posted on Jun 28, 2009
I have a 1992 Cadillac Seville 4.9 liter it backfires when is running what could cause that
Could be a timing chain, how many miles are on it? Is it now hard starting since it started backfiring? How long since last tune up?
Oct 11, 2014 | Cars & Trucks
Backfire on 2010 flstc?
Backfiring is caused by a lean air/fuel (A/F) ratio. A leaner A/F ratio takes longer to burn and will continue to burn in the exhaust, hence the backfiring. Is the bike stock, or have you changed the air cleaner or pipes? Both of these changes will result in a leaner A/F ratio. HD bikes with fuel injection already run lean to meet emissions requirements, so changing pipes, etc. will make the problem worse. If you have not made any changes to the bike, make sure that the fuel system is clean and you are using good quality gas. You can also have the bike's computer (ECU) remapped to run a little richer. Your dealer may be able to do this for you, or there are aftermarket ECU tuners available for your bike that can adjust the fuel map and ignition. These will give you the added benefit of more power and a cooler running engine.
Apr 24, 2014 | 2010 Harley Davidson FLSTC Heritage...
Backfire carb
Urals need to be throughly warmed up before riding, old technology engine. As far as the revving, I'd Check for vacuum leaks at the Carburator with some carb cleaner while idling, and if that's not it, I'd check the choke.
May 27, 2013 | 2010 Ural Patrol 750
Backfire problems
Check your timing
Aug 17, 2012 | Polaris ATV
Craftsman lawn tractor backfiring
clean the jets inside the carb
Aug 06, 2012 | Craftsman Garden
Backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
I have a sanli mulcher lawnmower about 3years old, always ervicedand looked after. last few uses its been gutless. today it was running but stopped. when I went to restart it, it made ratchetting sounds,...
Never heard of a sanli. If the engine is backfiring, indeed it could be out of time. One sure way to check if it is out, is to see if the flywheel key is sheared.
Please vote on this solution.
Sep 05, 2010 | Garden
Backfire
is it a straight thru exhaust, or is it just a head pipe with nothing attached? If it's just a head pipe, you need to get some sort of muffler on it or you'll burn your valves out from a lean condition. The backfire is due to the vaccum fed carbs that yamaha runs. They work wonderfully, but under heavy deceleration, the vaccum still feeds the bowl, and it builds up excess fuel, which eventually burns off as a backfire. If it were fuel injected, you could have the fuel map adjusted to lean it out under deceleration.
Jun 22, 2010 | 2001 Yamaha V Star 1100 Classic
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
663 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
