Question about Homelite Leaf Vac Attack
Homelite Vac Attack 2 starting issues
I am an auto tech and enjoy motorcycle, small engine repair. I have a homelite vac attack 2 and have trouble starting. Rebuilt carb, no apparent problems. when I manually prime the carb, it will start but seems to run on the lean side. There are no carb adjustments. The choke lever seems to raise throttle slide similar to mikuni style bike carb, raising needle to allow more gas without increasing air mixture. My friend has same model with the exact same problem. I believe it is CARB certified. From what I've herd they lean the heck out of them to pass this certification. Is there any recall on them or problem I am missing? Can I modify easily ?
3 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: what is the gas ratio for Homelite Vac Attack II
The mix that I would use is one ounce of two cycle oil per quart or four ounces of two cycle oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Posted on Aug 31, 2009
Testimonial: "thanks. "
  • 5 Answers
SOURCE: Need a user manual for Homelite Vac attack 2
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
Testing a coil from a vac attack II blower
remove the small wires from it and spin the engine over if still no spark the coil is bad
Aug 20, 2012 | Homelite Leaf Vac Attack
I have run my Homelite Vac Attack ii using gasoline only. Now it wont run.
You need to take to shop and have them check it out, more than likely the cost of Repairs will exceed the price of a new Blower, In other words Yes this Motor is NO GOOD . Sorry For the Bad News..
Oct 23, 2011 | Homelite Leaf Vac Attack
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Does my vac attack 2 need crank case oil?
It will have a 2 stroke engine, so the oil will be mixed with the petrol, so no you won't need any crank case oil.
Nov 09, 2009 | Homelite Leaf Vac Attack
Does this blower use 2 cycle mix; I have a homelite vac attack II 200mph blower and it is having trouble starting
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Oct 12, 2009 | Homelite Leaf Vac Attack
Need to know the right gas to oil mixture for a Homelite Vac Attack UT08107A
All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils
May 22, 2009 | Homelite Leaf Vac Attack
Homelite Leaf Vac Attack Logo
743 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
