Question about Ovens
Top burners on our Viking work fine, however the
Top burners on our Viking work fine and there is plenty of gas, however the ovens will not light.
  • ccottrell5 Jun 27, 2009
    No, unfortunately the ignitors are fine. It is almost like the gas isn't getting to the tube.
    President:
  • 1,136 Answers
Hi, There is a good chance the ignitor is bad. Even if it glows, it could be weak enough that it will not open the gas valve. It is very a common problem with the gas stoves.
I would change the ignitor.
Vic
Posted on Jun 27, 2009
  • Victor
    Victor Jun 28, 2009
    Do you hav a broiler and bake seperate burner? If it does, does the broiler work? Even tho the ignitor glows, it could very well be bad, I replace them all the time even when they glow.
    Maybe repost your question and see if other experts might help.
    Vic
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
I have a Viking gas single oven with four burners. The burners work fine but the oven won't fire up. I smell gass an I see a glow under the oven but no heat. But if I turn it to broil I get some heat but...
I had the same problem with the single oven, It the voltage feeding the oven, it like to be 120 or above if it drops below 120 then this problem occurs. I had ever thing checked, gas pressure, and the oven. Electrician installed a voltage regulator on that circuit.
Dec 30, 2010 | Viking Ovens
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not light.
heatman101
Apr 04, 2010 | Viking 27" Professional Select Built-in...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Nov 26, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
145 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
