Question about HP OfficeJet 6110 All-In-One InkJet Printer
How can i send a fax thru my internet connection
I have an hp officejet 6110xi all-in-one i have a cable modem for my internet service i do not have a phone line
    President:
  • 3,085 Answers
Fax systems are ANALOG your cable is DIGITAL, you will have to use scan to email if your printer has that option.
Posted on Jun 28, 2009
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
Fax Error 386, HP 6110xi Fax failed Is there a solution?
See http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
Too much noise on the phone line: e.g. bad connection, unshielded phone cable next to a electrical machine (motor!), temporary problems in phone service providers network.
Fax is essential data transmission by beeping noises. If crackling on the line or other disturbances degrade signal quality too much, the data cannot transmitted properly anymore.
Feb 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . mubashir@ellahifabrics.com
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
Oct 21, 2009 | HP OfficeJet 4255 All-In-One InkJet...
I can not send or recieve faxes. Ran fax test
Cox Cable is pretty much the same as comcast's and vonage's services. HP fax machines have had HUGE compatibility issues with those types of services, and may be that they did something to their service that caused your fax to stop working.....
Other than that call HP and see if they have any troubleshooting or Diagnostics that you can run, but I ran in to these problems with HP faxes all the time while installing comcast phone service, never knew WHY it didn't work, just that HP doesn't work on that type of service.....at least certain models...Also maybe call COX and see if they did anything recently that could cause it to stop working....
Jun 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have cable modem for my internet. I dont have any phone service
No. fax machines are ANALOG devices. Cable Modems, DSL, Vonage etc are DIGITAL.
Feb 11, 2009 | Canon FAX-L350 Plain Paper Laser
Setting up fax with modem
try to used the two conductor cable that came with the printer itself.
- at the same time ask for a filter from your phone provider
- the printer should be direclty connected to the phone walljack
- if you have all this kind of set-up you will be able to recieved faxes now..
send comment/feedback fo furthere troubleshooting...
Aug 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Cannot send faxes!
Take an ordinary phone and connect it to the auxillary port on the back of the fax. Call the number you are trying to fax and listen to see if it connects and the other fax picks up. Be sure you are using any prefix numbers required such as a 9, or a 1 and area code if required. HP recommends that you use a 2 wire phone cable, not a 4 wire (see how many metal connectors are in the jack to tell). Of course, if you are on a DSL line you want a filter installed for the fax. If this doesn't work, try a different phone cable. You could also have a bad modem in the fax. That would be last on my list. Good luck.
Jun 10, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
