Question about Brasstech ''P'' Trap Kit - 3013
I have a large whirlpool tub in MB on 1st floor. When letting water out of tub it is coming up in a large walk-in shower. The shower is draining fine...need answer! thanks
    New Friend:
    Problem Solver:
  • 5 Answers
The drains might be getting slow but the easiest way is to install a backwatervalve on the shower drain which would stop the tub from coming up inside the shower
Posted on Dec 01, 2012
    Problem Solver:
  • 19 Answers
Sounds like there may be some blockage in pipes. try to run a long snake through both drains or run all fixtures in bathroom and try plunging vigorously in tub and shower while running water. if nothing still, it may be possible that your underground plumbing is back graded or incorrect fittings and plumbing installation.
Posted on Jul 07, 2009
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Mar 09, 2014 | Jacuzzi - Bathtub - Alcove - Navona -...
I need to pump out a large tub in my basement to my drain because my drain is 8 feet off the floor. do you know where I can buy this pump or what it is called thanks jimmy and susan
you need to get a pump that will push water about 10 feet. sump pump is probably what I would use. Sears usually carries pumps like that as well as Steve Regan Company.
Dec 18, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My shower will have been turned off for hours all of a sudden it gives one large gush [drip] then will not drip for a while but will do so intermittantly. ps. this is a shower not a bath tub / shower
This is not necessarily an issue, air enters slowly and eventually lets some water escape. This may happen until the water is lower than the highest point of the shower discharge circuit.
Dec 12, 2010 | Moen & One Handle Tub & Shower Faucet
I HAVE THE AMERICAN STANDARD WALK IN TUB WITH THE QUICK DRAIN AND WHEN I FILL IT UP TO USE THE JETS, THE DRAIN WILL NOT RELEASE TO LET THE WATER OUT. WHAT MIGHT BE THE PROBLEM?
It could be the pressure on the drain isn't allowing the rubber around the drain pop up to come unlodged from the floor of the tub. I have ran into this problem a few times. the best way we found to take care of it was to install a push pull type drain assembly or try and adjust the drain pop up so it pops up higher allowing the rubber around it to break the seal and start to drain. take some pictures and post them i might be able to help more
Jul 19, 2009 | American Standard 1583.470 Universal...
When washer goes to spin cycle it doesnt drain water
Remove the hose from the drain and lower the hose to a floor drain or a large bucket. If water flows, there is a failure with the pump. If no water flows there is an obstruction, such as a sock lodged in the drain path from tub to pump. Either condition will require some disassembly to repair.
Jul 12, 2009 | Whirlpool Washing Machines
Clogged Drain in Whirlpool shower/tub
what you would have to do is this measure how far in to the line you are figure out what wall pipe is in cut access hole to pipe cut pipe and clearout blockage replace pipe your best bet is to go pick up the 3 peices of plumbing first 1. pipe 2.conections
Dec 21, 2008 | Brasstech ''P'' Trap Kit - 3013
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
As my washer tub fills with water it also empties to the drain.
must be new whirlpool,drain hose may too far down stand pipe pull up till about 8 inches is in drain ..is stand pipe 36 inches at least above floor?if not call plumber end of drain hose should never be lower than water level in tun also be sure there is air gape around hose to prevent siphoning ..this will usually occur after 1st drain and during rinse fill
May 05, 2008 | Washing Machines
Brasstech ''P'' Trap Kit - 3013 Logo
108 people viewed this question
Top Brasstech Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Brasstech Plumbing Expert? Answer questions, earn points and help others
