Question about Dishwashers
What does add rinse aid and where do you put it kitchen aid dishwasher
    President:
  • 3,085 Answers
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Posted on Jun 28, 2009
Where do you put rinse aid
For most dishwashers, there will be port on the door. Usually it will be near the detergent dispenser. On mine, the two items are in one grey plastic enclosure. The rinse aid port is on the right side of the area as you look at the dishwasher door from the front of the dishwasher. Look for a knob surrounded by a few numbers and a few symbols/words. In one direction, the dispenser will be closed; no rinse aid will be released. Turn the knob fully in the other direction, it's open and the cover can be pulled up to allow for refilling the dispenser.
I hope this helps. Please add a comment with your dishwasher's make and model number for more information.
Apr 06, 2015 | Dishwashers
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
My dishwasher says rinse aid,
From what I get from the question, it is asking to add rinse aid to the rinse aid compartment next to the dish soap compartment.
Dec 21, 2010 | Bosch Dishwashers
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
My dishwasher is leaving a white thick film on my dishes.
Check your inlet water quality. If hardness is noticed add salt as per the directions of the manufacturer. Refer user manual.
Check the rinse aid compartment and fill it with rinse aid as recommended by the manufacturer.
Apr 13, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Miele Novotronic G842SC Plus
Add the requested rinse aid.. The light is on telling you it's low/empty.
Oct 20, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
573 people viewed this question
Top Dishwashers Experts
