Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Losing focus I have a 2100 that will lose focus in wide angle after it has been manually set in telephoto. Oddly enough when you zoom back in the focus is still there. Is it possible the servo for the zoom is moving the focus ring as well? Any help is much appreciated!
    Problem Solver:
  • 13 Answers
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Posted on Aug 29, 2008
Autofocus Failure - stopped working
Replace the broken ribbon cable in the lens
May 23, 2010 | Canon Zoom Wide Angle-Telephoto EF...
Wanted to know how to change the settings on my lens
Having gone over a month with no response, I assume this is no longer a problem.
May 15, 2010 | Nikon Zoom Wide Angle-Telephoto 28-85mm...
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
"hand" icon flashing
It's likely your photos are blurry from camera motion, caused by taking a hand-held photo with a slow shutter speed, rather than out of focus.
The hand icon flashes when you don't have enough light to take a crisp (not blurry) photo without either using a tripod (or a flash). The reason for a flashing hand is you can't "hand-hold" the camera at the current settings - you need to use a tripod. If you are "zoomed in" (on a telephoto setting for your lens) you can sometimes get a crisp hand-held photo if you "zoom out" to a wider angle setting on the lens. (You need a steadier hand to hand-hold a telephoto lens setting than a wide-angle lens setting.)
You may have changed a setting that sets the ISO (the normal setting would be "auto") and if so, if you change the ISO to a high number, or to auto, this will help you take better photos in low light. Check your camera's user's manual to see how to check/change the ISO.
When you have more light the icon will stop flashing. If you need to take hand-held photos in low light then you need to use flash, or get a better camera that has better low light capabilities.
Dec 14, 2008 | Nikon Coolpix 5200 Digital Camera
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Go Ahead. Use Us.
May 31, 2008 | Cameras
Zoom button is malfunctioning
tons of people w/ any canon elura series cameras including myself, with a canon elura 80 have the same zoom problem. It does not appear that canon has done anything to try to solve this mass problem with this series of cameras. Oddly enough the only way to solve this problem is to give it a tap and gentle hits near the zoom button to release what would seem to be a jam. Sorry that there's really no straight forward answer, but for now its the best i can give.
May 03, 2008 | Canon Elura 80 Mini DV Digital Camcorder
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Epson 3000Z in "sports" mode
With the telephote lens, I am assuming that the camera is a bit more sensitive to any form of camera shake. My suggestion, when using the telephoto lens, is to manually set the shutter speed to its fastest setting (that, or set it to "sports mode"). Also, experiment with the telephote lens using your tripod. Set the camera up on a table and use the timer so that the camera will snap the image automatically. See if the picture is still blurry. If you don't have a tripod, just place it flat on the table.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Focus Problem
As stated on page 145 of the A2 manual: "When using this camera with the optional supplementary lenses, the accessory must be specified in section 5 of the setup menu. For more information on the Wide-angle Converter ACW-100 or Telephoto Converter ACT-100, contact your local Konica Minolta dealer. A firmware update is provided with these products to activate this option."
Sep 13, 2005 | Konica Minolta DiMAGE A2 Digital Camera
S70 Macro Focus Problem?
The macro is good at 4cm at wide angle, 8inches at full telephoto(different distances for any focal length in between). I read that someplace in the manual, I believe.
Sep 11, 2005 | Sony Cyber-Shot DSC-S70 Digital Camera
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
275 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
