Question about Garden
Toro Recycler with Techumseh enging will not start
It is 3 years old, 6.5 hp, manual start. Not a 2 pull performer. Spark plug is wet with gasoline. Has compression, gas, and spark. I am at 6700 feet elevation. Perhaps I need smaller carb jets? Also, I have NEVER had good results with Champion spark plugs. This will be my first try to resolve the problem. I only use the mower 2 or 3 times a year. Gas is fresh.
  • 78 Answers
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Posted on Oct 29, 2009
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Aug 18, 2011 | Toro Power Lawn Mower
I have a Toro recycler approx 2 years old. No spark, cleaned flywheel and magneto and its getting gas. Has the primer button on the side for starting. Please help. No key start.
Check to see if there is a wire off under the shroud that will run to the magneto. May have a hole rubbed in it allowing a short. The magneto should not be bad being only 2 years old, but it's possible.
Oct 24, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro recycler lawn mower that was made in 2005 according to the sn. it wont start. we have tore it down to check everything but still nothing. It has spark. after pulling a few times we check the...
If you have spark and gas, it should start. The plug shouldn't be wet with gas, adjust the carbuerator fuel flow screw to reduce fuel to the engine. Use full choke to get it started
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Type of gasoline for Toro Recycler 6.5 HP
Without the mdl # I can't be for sure but I am 99% positive it is unleaded. Same as your car if you are in the US.
Kurt
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
429 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
