You can find the manual for your systems
here. You can either print it out or look at it in the webpage. If you go to page 4, you should see a diagram of your remote control. You are looking for buttons 17 and 20. One has a little temperature picture with an arrow up and an arrow down, that will raise or lower your temperature. Button 20 is on the bottom right of your remote, which will change your mode (fan, AC, Auto, Heat, etc). Press 20 until you see an A on the display, which symbolizes "Auto" mode, then change the desired temperature with 17 until it's at the level you want.
If this isn't the proper manual for your system, could you please find the model number and post back with that? It makes it a little easier to find. The model number should be located on the unit itself somewhere, or possibly on the outside part of it.
