Question about Labtec Microphone Microphone
Does not work
I have a labtec AM-242Microphone that was given to me by my daughter several years ago and I never have used it. I now have a program where I am trying to learn spanish and I need the mike. It looks like I need to install it and I do not have a install disk. Is one available or can I download the installation?
Re: does not work
I had the same problem it's because your plugging it into the front of your computer....plug it in the back and it should work....there should be something that pops up or click in the right hand corner there's an icon that says sound need to acknoledge that it's a mic not a cam that your plugging in
Posted on Oct 28, 2008
0 characters
3 Points
How do you unmute the Beta 87A wireless microphone
Look at the manual, the Beta 87A can be mounted on several shure microphone series. The shure web site has manuals for free.
Jan 06, 2014 | Shure Microphones
I have a shure UT4 reciever,what microphone that will work for that type of reciever? my was lost,thanks
Only a UT transmitter will work with that receiver. The transmitter must be on the exact same frequency as the receiver. Shure discontinued the UT series several years ago, so it will not be easy to find one.
Dec 30, 2010 | Shure UT12485TD Professional Microphone
Hi i have this system 2X Shure LX4 Wireless MARCAD Receiver + SM58 Microphone can i buy seperate SM58 MICROPHONE to use in this system? thx. mike
The LX series was discontinued by Shure several years ago. They no longer have any new transmitters that would work with your receiver. You could look for a used transmitter, but it would need to be on the exact same frequency as your receiver. That will not be easy to find.
Dec 20, 2010 | Shure LX-2 With SM58 Professional...
I need a Shure T2/58 transmitter
These were discontinued several years ago. You'll have to watch eBay or Craigslist. If you find a used one, it will need to be on the same exact frequency as your receiver in order to work. It won't be easy to find one on the same exact frequency, so good luck with your quest.
Oct 26, 2010 | Shure T2/58-CL SM58 & Wireless Transmitter...
Labtec mic plugged in but not working
• Check all connections for the "(type of microphone)" , make sure the microphone switch is set to the microphone button. • If you are running windows® 95 or later, check the microphone volume settings. 1. Go to the start button, All programs, Accessories, Entertainment(multimedia), then Volume control. 2. Make sure the microphone volume isn't set to mute.
3. go to options, then Properties..., select the button next to Recording
4. go to start button, All Programs, Accessories, Entertainment(multimedia), then click on Sound recorder to test your microphone.
Hope that helped! ~xiviogwiffi
Mar 15, 2009 | Labtec AM 242 Desk Boom Microphone...
Labtec Microphone
what is your operating system.
Aug 18, 2008 | Labtec Desk Mic 534 Consumer Microphone
Labtec microphone
try to adjust the line in volume when you double click the volume icon, it may be muted
Jul 24, 2008 | Labtec Microphone Microphone
Labtec verse 504
If you are using skype, go to the upper left hand top and click on call. Then click on audio settings and make sure your microphone is listed as the mike to use in the window of the drop down menu. It should say logitech something in the window that says microphone.
Jan 21, 2008 | Labtec Microphone Microphone
Labtec Microphone Microphone Logo
188 people viewed this question
Top Labtec Microphones Experts
Ben Armstrong
Are you a Labtec Microphone Expert? Answer questions, earn points and help others
