The spin cycle doesn't work anymore - Washing Machines
    Problem Solver:
  • 6 Answers
Check to make sure the switch is working when you close the lid,alot of the time the switch breaks loose and will keep it from spinning cause it thinks the lid is open,remove top of washer and inspect switch
Posted on Jun 27, 2009
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Won't read any kind of disc it spins and stopped like 3 times and doesn't move anymore
Sounds like you later lens has been damaged or is dirty. There is a cleaning kit at Walmart. If that doesn't work, google a local repair shop.
Feb 16, 2013 | Video Game Consoles & Games
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Jun 09, 2011 | Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
My spin cycle on my maytag washing machine wont work. All else works fine but it wont drain or spin??? Please Help
check th elid switch to unit as it may have failed... it will stop the unit from going into a spin cycle and draining,,, give that a look and repost if you have anymore questions... good luck
Jan 09, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
