Question about Boating
My boat Merc Cruiser V8 4brl, Thunderbolt IV 1978. Won't run well or idle, it back fires stutters and dies. This happens after it worms up. I rebuilt carb, cleaned out the old fuel, new fuel tank, Runs fine for a few min and then goes crazy.
    Champion:
  • 207 Answers
You need to replace your coil it is only about 15.00 it doe not sound like a fuel problem if the coil doesnt work you need to look at your cdi if you have the outdated box it will be mounted on the distributor it about a 1/4 inch thick 3 inches long and 2 inches wide with one flat plug going in it. before you do that change your plugsand wires wait im sorry i just saw the year of the boat now were getting somewhere you have a bad codenser if your boat has points under the distributor cap the condeser is the little siver cylinder while your in there you should just get a kit cap,rotor, button,points and condesor the points should be set at 25 to35 thousands i asume that 1978 is theyear modle if not like i said the new cdi box is out of date and very expensive $498.00 to be excact i would do a good tune up before turning to that but if it is a 1978 the distributor tune will fix your problem kit is about 70.00
Posted on Jun 28, 2009
What size and year is my mercury outboard serial n 5266428
It's a Merc 45 from 1978. Serial numbers 4869518 thru 5270783 are 1978.
Apr 30, 2016 | Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2016 | Motorcycles
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
What size and year is my Merc outboard serial# 6181919?
Good Morning James,
From The No Given I get That It Is A 150Hp Mercury
Year Is Between 1978-1985
Regards
Gordy
Jun 11, 2015 | Boating
Mercury outboard
RE-SYCHRONIZE CARB(S) AND IGNITION COMPONENTS PER SHOP MANUAL
Jun 30, 2013 | Boating
1996 merc. xr6 cutting out
Could be throttle advance linkage, loose electrical connector, or ground.
Jun 07, 2013 | Boating
2005 Victory Touring Cruiser idling too high - What could cause this?
Yes could citernly cause it but you must check if it has a idleing screw and if it does you can turn it down, or the cable might be pulling tight or fraing even a little dry.
Dec 01, 2011 | 2005 Victory Touring Cruiser
My 1978 GS750 has a stumble right of Idle, any ideas? Carb settings? Thank you.
needs just a little more air on your idle mix screw and if that won't fix it, take your carb slide out and drop the inlet needle down 1 notch so as to take a little fuel away during idle, that makes it come on more crisp & clean
Apr 24, 2011 | 1978 Suzuki GS 750 E
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
Boating Logo
117 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
