Question about Sony Alpha DSLR-A700
A700 flashing "lens" message
I have a compatable lens attached to my sony a700 using an attachment its turned to manual setting ,,zoom works great but when i try to take photo i get a message lens not attached shutter locked.I was assured when i bought lens and attachment it would work on my sony ..AM I DOING ANYTHING WRONG???
Is the lens switched to manual as well as the mode dial. If the compatable lens is a minolta requiring an M42 adapter make sure that the protruding arm/rod is operating the shutter when depressed and that the adapter when fitted operates the lens when turned from auto to manual. Good luck.
Posted on Dec 30, 2009
How to get lumix g1k to work with an adapter and legacy lens. in viewfinder it states "make sure lens is attached correctly
On page 141 the manual says
[PLEASE CHECK THAT THE LENS IS ATTACHED CORRECTLY]
• Check that the lens is attached correctly and then turn the camera off and on. > If the message persists, contact the dealer or your nearest Service Center.
on page 14 the manual says :
This unit can use the dedicated lenses compatible with the Micro Four Thirds System lens mount specification (Micro Four Thirds mount) such as the lens included in DMC-G1K. Select a lens that matches the scene being recorded and your use of the pictures.
If you use a lens other than a dedicated interchangeable lens, auto focus cannot be activated and accurate metering is not possible. Also, some functions will not work.
You should put the camera in mode manual, to avoid the error you get.
to see what lens you can use see what the manual says:
Refer to catalogs/Web pages for most current information regarding compatible lenses. http://panasonic.co.jp/pavc/global/cs (This Site is English only.)
Oct 29, 2013 | Panasonic Lumix Cameras
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
CAN I FIX THIS LENS??
not a easy fix. when it is not connecting it defaults to the widest aperture so it is letting in as much light a possible. you could try speeding up your shutter speed and see if your start seeing a image
Aug 05, 2012 | Sigma 18-250mm f/3.5-6.3 DC OS HSM IF Lens...
The auto focus on my Sony A is not working. It
Usually the gears will strip the lens gears which tend to be plastics whereas Sony a cameras themselves have metal driven cogs....I once stripped a sigma zoom using an
A700 simply because the motor on that camera had no feedback on torque...put a different lens to check this out first...then check the faulty lens the cog is visible once you remove the rear mount.
Nov 11, 2017 | Sony Alpha DSLR-A100 Digital Camera
AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Feb 20, 2009 | Pentax *ist DL Digital Camera
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Sigma 75-300mm + sony alpha 350
If it is a dynax compatable lens it should work The really old 75-300 shiny black finish will not work
and can not be rechiped
Oct 02, 2008 | Sigma Cameras
Zoom Lens
Hey TLY71,
I don't know of any zoom lens for this camera, but there are a few attachment lenses for this camera, and I have provided a link to those below.
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Sony Alpha DSLR-A700 Logo
258 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
