Question about Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Picture settings won't save
I have attempted to adjust the picture settings to "cinema" but they eventually revert back to "vivid". I don't see a button that saves the settings. I'm not sure what to do. Also, when it reverts back to "vivid" the volume readjusts, usually higher. Please help.
3 Suggested Answers
  • 718 Answers
SOURCE: RCA ColorTrack 2000 - Picture getting small at bottom. Black line
Its the capacitors going bad. I believe you will see them as a pair.
Posted on Feb 24, 2009
  • 9 Answers
SOURCE: Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Posted on Apr 29, 2010
What is the default setting numbers to get a good picture on a 42 inch ilo
Hi Darlene, Good picture is the one which is pleasing to watch and comfortable to your eyes. Please go to picture setting menu and set the levels of contrast, brightness, colour, sharpness and backlight to your liking. If you find it difficult, please go to picture MODE and select the one you like from standard, vivid, soft, and cinema. Happy viewing.
Apr 01, 2015 | iLO Televison & Video
How do I factory rest my Lg led smart tv?
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 10, 2014 | Televison & Video
When I change picture settings from my remote why does it revert back to old settings
Main system control memory IC fault. Contact any service technician to replace it. Before replacing this IC; do a reset to this set and check.
Sep 10, 2014 | LG Televison & Video
Ican't qdjust the color on my Samsung LED screen
Follow the below mentioned steps :
1.Turn on the LED TV and let it warm up for 30 to 40 minutes before making any changes or adjustments.
2. Put on the lights that you would normally use when watching the TV. You want to create the same ambiance that would constitute normal watching conditions for you. Make sure there is no glare or reflection from other items in the room such as a mirror.
3.Open the menu on the screen of the LED TV with your remote control and find the options for adjusting the color, contrast and brightness. Menu options will vary by TV, but look for options that will say "Contrast," "Color" and "Brightness."
4.Start with the "Brightness" control. It would be best to have a DVD playing so that you can get a better idea of the control settings. Pause the picture at a place that you can see a variety of scenery, such as sky, mountains and people in the forefront. Adjust the "Brightness" by pressing the up and down arrows until you are happy with the picture. Press "Save" or "OK" to set the brightness at this level.
5.Repeat this with the "Contrast" and "Color" controls, remembering to save your settings. Look for the "Mode" setting. Press the arrow to get to "Normal" or "Movie/Cinema." Press that setting and save it.6.Turn off any settings that are titled "Flesh Tone Correction" or "Vivid Sports." These will make the colors unnatural, use up energy and damage the TV over time.
Jun 26, 2011 | Computers & Internet
KDL-52S5100 Picture settings always revert back to "vivid" mode after 5 mins or so.
More than likely the TV is in the "retail" mode which intentionally reverts to the "vivid" mode after a short period of time on the other settings, deemed best for retailer display puposes.
Follow the "return to factory settings" instructions found in the operators manual, pg 21 of KDL52S5100. Only the first half of the instructions are needed to put the TV in "home" mode, the 2nd slection to make after "language. After you have slected "home" I do not beleiev you need to any go further into the setup menu.
"Turn the TV on. Press and hold the "^" (up arrow) button on the remote and then push the "Power" button on the TV. Release the "up" arrow."
You should now be back to start, select langauge and home mode and then exit.
You now should be good to go and your picture mode selections should now stay put.
Sony has live tech help "chat" and I would suggest using them if this doesn't get it done - but I'm 99.95% sure this is your fix.
Jan 05, 2010 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
When i change the picture settings to my custom selections, it always reverts back to the vivid preset after about 5 minutes.
Most likely you are in "retail" mode which intentionally reverts back to "vivid" which is deemed best for store display purposes.
Go to pg 21 of the manual and follow the first half of the reset instructions. Once you've chosen "home" (after first selecting "langauge") you need not go any deeper into set-up mode, just exit at this point.
99.95% sure this will solve your problem and your "picture" selections will now stay put.
Oct 28, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture setting reverts to Vivid
LG replied to my enquiry abd apparently the TV was in store mode. Just required a factory reset,...seems to have done the trick !
Jun 03, 2009 | LG 42PG20 42 in. Plasma HDTV
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
