Question about Kenwood Audio Players & Recorders
Tapes aren't audible although amps & speakers work fine with other components
  • beecee7 Jul 10, 2009
    Thanks for the suggestions. I now suspect that the problem is with the tape deck's output.
  • 441 Answers
Look more a button label "tape mon" and turn it off, if you cant find that button try hooking it into another jack on the amp to make sure the deck is still outputting
Posted on Jul 10, 2009
Why will Amp not produce sound unless the input and output are patched together
A typical stereo receiver / amp consists of switching low level input signals (CD, DVD, Phono, DAT, etc.), processing them and then output to the amplifier (low level) input for amplification to levels needed to drive speakers. The low level signals would barely be audible via an earphone, so they need to be boosted significantly in order to drive speakers.
Some amps provide jumpers to insert into the phono jacks on the rear of the amp to bridge the processed low level output signals into the low level amplifier input. You could install a Y cable here to feed two amplifiers - or - connect a tape recorder's "REC L+R" to the low level output and the "PLAY L+R" to the low level amp input so that you'd hear the actual audio as it had been recorded on the tape.
If you remove the jumpers (or tape recorder if used instead), there is no way for the low level audio to get into the amp's low level inputs for amplification.
Feb 24, 2015 | Audio Players & Recorders
Aiwa turntable not playing through the speakers
Has the amp got a dedicated phono socket for the turntable? If you are using a tape or aux socket it might not have the pre-amp needed to hear the deck. If your amp doesn't have a socket for the deck, you will need a magnetic cartridge pre-amp.
Also check the connections to the cartridge, they might have come loose.
Jun 09, 2014 | Aiwa PX-E860 Turntable
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
I have no sound out of the front speakers. Mute button is off, speakers work fine. Only have sound (very little) if volume is turned way up.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's
full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume
it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape
Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead'
spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like Tape
Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 10, 2011 | Yamaha RX-V870 Receiver
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
Apr 09, 2011 | Onkyo TX-910 Receiver
Bose 901's with Onkyo A9755B
Did you buy the 901's new along with the eq? If you did then I wouldn't suspect it to be the eq. If you bought it used, it sounds like the eq. I have had two of them go bad. Are you cutting the bass up on the Onkyo? Do you have the speakers placed correctly, like 18" from the wall? These speakers don't have a lot of bass unless they are placed correctly against a wall. They really sound best in a corner. You should get a difference when you move the opts on the eq though. Hope this helps some
Jul 13, 2009 | Bose 901 VI Main / Stereo Speaker
I have a Bose Accumass 6 system connected to an Onkyo amp running as a entertainment system on our boat. The quality is sufficient for what we need. The amp (a TX-DX575) has A&B speaker switches for a...
two 8 ohm speakers in parallel is 4 ohms.
if series 16 ohms.a high resistance will just produce less power.
too low a number can activate the speaker protect,or blow the amp.
radio shack sell wall mounted speaker controls,but 5 watt max.
the best thing is to run 2 amplifiers.one for in ,2 for out
speaker a and b on the amp parallel the speakers.
if you run 2 sets of 4ohm speakers,the amplifier load will be 2 ohms,and overheat the amp.4 8 ohm speakers,gives a 4 ohm load
May 09, 2009 | Onkyo TX-DS575 Receiver
I bought a Denon AVR 3808 receiver. Bose says my speakers EQ is not compatable for this AVR. Is there a list of compatable receivers for these speakers...seems confusing...should I return the speakers or...
You might be faced with the age-old Bose issue of a 4-ohm speaker set. The ohm rating must be compatible. Most receivers drive 8-ohm speakers. If indeed they are incompatible, then it's up to you which component you want to replace (I don't recommend trying to find a converter to use the Bose speakers). The receiver sounds like it is new, so perhaps the speakers... or return the receiver and get one that can drive the Bose.
Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
My technics se hd 51 amp seems to have stopped working. I have a barely audible sound when turned up to full vol. Any suggestions...can I d.i.y. this job ? many many thanks. Technics SE-HD1 Stereo...
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Jun 23, 2008 | Audio Players & Recorders
Alpine cde 9852
In actuality the resistance of the speaker depends on the frequency the speaker is playing. For example, a speaker may have a 3 ohm resistance at 80 Hz and a 9 ohm resistance at 300 Hz. If you were to make a plot of resistance versus frequency you would get what is called the impedance curve of the speaker. Also, speakers act in some ways as inductors and capacitors so a true model of a speaker must include those components as well. How does this affect the sound you ask? Well if you have an amp that has very weak current capability it may work fine into perfect 4 ohm loads but when you connect our real speaker which has an impedance dip at 80 Hz the amp may have difficulty and smear sounds that have 80 Hz components. These are minor but audible effects. This is why it is good to get a 2 ohm stable amp even if you never plan on running 2 ohm loads.
Mar 03, 2008 | Alpine CDE-9852 CD Player
50 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
