Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Professional 6, shaft dropped down or metal washer slipped down
KitchenAid 525 Watt KP2671XWH.
How long is the shaft portion that protrudes from machine housing supposed to be? I am not sure if shaft dropped or if the metal ring came down,though it is very firmly set.
while mixing cake frosting it made a grinding sound for 5 seconds. I shut it off, paused then started it up
it kept working, sounded normal then grinding occurred once again. I am afraid to use it to prevent further damage.
After reading some of these entries I think it is the gears. I have an early 2004 model Pro 6, probably plastic gear housing(!).
Is there a lawsuit or recall afoot? It seems when you profess heavy duty and Professional quality and then use plastic parts it is fraud, waste and abuse!
  • shannonjaye Jun 30, 2009
    In addition could I get exact replacement instructions, repacking grease etc. I've never done anything like this before & I have read all the other problems/solutions related to this product on this website. Before posting problem I looked up my model at kitchenaid.com for parts list. I just don't have the process beyond opening it up.
    Novelist:
  • 166 Answers
Actually, the core component of your KitchenAid is a motor which should provide enough torque to rotate any amount of load applied to your appliance. But the fact is that torque ( force ) produced by this motor is NOT getting delivered to your LOAD and hence it is SLIPPING at heavier loads.
But good news is that still you motor is working fine and all you need to adjust & repair the component between MOTOR & load. Its slipping due to high load and hence it is making such noises. So don't worry after alighnment, it will be ok.
With Regards,
Shyny Saxena
Posted on Jun 30, 2009
    Sergeant:
  • 326 Answers
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project
Posted on Jun 28, 2009
Removing worm follower gear in a Kitchenaid Professional 600 mixer
You need to drive the pin out with a punch. The pin should not be crimped on both ends, but could have been damaged if the gears stripped out.
Page 6 of the service manual walks you through removing the worm follower gear and dropping the planetary. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 22, 2013 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
I can't find the model number of my kitchenaid professional 525 watt 6 quart mixer. I've taken it apart and don't find any numbers that resemble a model number. Any suggestions?
According to the website the model number for a Stand Mixer should be on the bottom and back of the stand mixer.
If you are seeking a Manual for your mixer search here:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KA_EN_CA
Your model number may be KP2672 plus an additional four characters. You can search on the partial model number you have but you will come up with 50 possibles.
Feb 06, 2011 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid 6 qt mixer repair
A small screwdriver or needle nose pliers will work to remove the cir-clips that hold on the shaft.
Apr 24, 2010 | KitchenAid KP2671 Professional 6 Series...
I have a Sunshine Yellow Kitchenaid professional 6, 525 watts with three mixing attachments, and pouring shield, in mint condition, just had it in the repair shop to replace the plastic seal (not sure if...
Hi Lisa. Your mixer's plastic transmission housing failed when you were mixing bread dough or cookie dough. When this cheap plastic part fails, it can cause internal damage to the worm gear shaft, worm gear bearings and their seats as well as other internal damage. This kind of damage is not easily found, as the grease inside the transmission must be removed and parts cleaned to fully acertain damage. If the trans. housing was the only part replaced, I would view the repair as only partial.
If the mixer now runs well, without any internal noises during operation, consider yourself fortunate. You could advertise that you have upgraded the mixer (metal housing). A price between $200.00 to $250.00 would be in the ballpark.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 22, 2009 | KitchenAid KP2671 Professional 6 Series...
The attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
Agitator Shaft in Planetary
You need to carefully tap out the pin that goes through the gear and the shaft to remove it, You can find the parts list by entering your model number HERE.
Aug 23, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
76 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
