Water accumulates in the bottom of my air conditioner until fan
    Scholar:
  • 70 Answers
Check unit for being level if is a window unit. clean drain and or put some bleach in it to help clear it out.
Posted on Jun 28, 2009
Leeking water a lot
Condensate water accumulates in the evaporator.There is a tube that drains the water out of the evaporator to the condenser side where the fan picks it up or an external drain. The tube is plugged. It needs to be cleaned out.
Jul 05, 2015 | Haier 12,000-BTU Commercial Cool Portable...
How can I get the water out of my 253.70121 window air conditioner outside case. The fan blades hit the water.
When I was a Maintenance Superintendent for a Senior Citizen Apartment Complex, we had two window air conditioners with the similar problem. This is what WE did, and it worked for us:
1. We ensured the window air conditioner casing was, in fact, tilted slightly for proper drainage. Water continued to accumulate.
2. We drilled two holes from the drain pan, through the casing and added an additional PVC fitting and PVC piping to accommodate the new drain and make it more appealing to the wondering eye.
Good luck.
Aug 26, 2014 | Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
Water accumulation and ice buildup
There is already a hole just remove the ac unit from the window,and it`s shell,take it outside and use a water hose to clean it out,and remove anything on the inside that may stop up the drain hole.This needs to be done every year before spring or summer.If this was at all helpful,please rate,thank you.
Jul 12, 2010 | Samsung AW0891M Air Conditioner
Water has accumulated in my air conditioner...
You need to check to see if the unit is off-level, as it should be. From the outside, the unit should appear to be slightly tilted to allow for water run off. Also, check to make sure the water drain hole or holes are not clogged with debris. Remember, an air conditioner is also a good dehumidifer and the water that it removes from the air it is cooling must go somewhere.
Sep 11, 2008 | Hampton Bay HBLG5004 Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Air conditioner is emitting condensation through top of unit
The manual said to remove the rubber cap on the back, exterior, of the unit, insert the drain plug and push down lightly to drain off the excess water accumulation. However, a drain plug was not included in the package. Furthermore, there wasn't an actual "hole" in the unit to insert it. I did drain what I could by just leaving the cap off. This did not take care of the problem completely. Next, I unscrewed and removed the the front, interior, of the housing unit. I then noticed additional water buildup in the bottom of the unit under the sling fan. I could not remove the fan, so I used a turkey baster to **** out what water I could. I know - resourceful don't cha think! Then pushed paper towels into the bottom of the cavity to absorb any leftover water. Whaaala - problem solved.
Thanks for your prompt response.
Teresa Wellman
Jul 13, 2008 | Goldstar Heating & Cooling
Water in housing
You will need to clean the evap coil with a bleach type product and then hose out the condenser coil as well. The bleack will also remove algie from the evap water pan. THX RepairUSA
Aug 26, 2007 | Goldstar R5050 Air Conditioner
Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Aug 02, 2007 | Maytag NMPEB08F2A Air Conditioner
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
