Just got home - Lennox Elite 10 CB29M is not cooling ---fans are working, but no cooling. Manuals left by builder of no help.
3 Suggested Answers
  • 588 Answers
SOURCE: Just got home - Lennox Elite 10 not cooling ---fans are working
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Posted on Aug 25, 2009
  • 9 Answers
SOURCE: water is leaking into my garage when A/C unit is r...
Check your indoor unit. your problem is there. you will be able to see where the leak is coming from then I would be able to help you more
Posted on May 22, 2010
My lennox elite series cb29m-41-1p is leaking alot of water in the house with the air conditioner on. drain line to outside is clear
The condensation pan in the unit must have no cracks our brakes, and needs to be tilt down toward the condensation drain line, algae builds up clogs and must be cleared of clogs periodicaly
Aug 05, 2017 | Heating & Cooling
Lennox air conditioner. Outside unit fan stopped spinning. Air coming out inside the home. Unit is on and operating. Fan just stopped. What is wrong and what should i do?
Hello, this sounds like a bad capacitor or bad fan motor. Replace the capacitor, if replacimg the capacitor does not work you have a bad fan motor. Capacitor is usually about 10 bucks where a motor is about 200. So try repacing the cap first.
May 28, 2011 | Heating & Cooling
I have a Lennox CB29M Air Handler with an electric heater, which is used to heat the lower two rooms of my house. The handler unit is located in a mud room right behind the back patio. I'd like to get an...
Any of these Lennox dealers can help you choose a compatible HS29 or HP 29 condenser and evaporator coil to match your system.
http://www.lennox.com/locate/default.asp
Jul 06, 2010 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
Water is leaking into my garage when a/c unit is running. Lennox elite series cb29m-41-1p
May 19, 2010 | Heating & Cooling
The fan is running and blowing cool air out of the unit but there is no air coming through the vents, what are the possible problems? (Lennox Elite series)
The unit could possibly have a frozen indoor coil. Turn ac to off...and fan switch to on...wait 45 minutes and see if air flow improves. Check for dirty filter which can lead to freeze up. Low on freon is also a possibility.
May 18, 2010 | Heating & Cooling
Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
Jul 28, 2009 | Heating & Cooling
Heating & Cooling Logo
392 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
