Question about Sony Audio Players & Recorders
I have a receiver and after 3 minutes. It,s appear"protect" and all stop. Can you telle me what's wrong.
  • 100 Answers
Check speaker,speaker wire and output transistor in amp.looks shorted.
Posted on Jun 27, 2009
Receiver worked last night. I turned it on this morning and it just clicks over and over. Never comes on. I have to unplug it just to make it stop clicking.
What is the model number of this receiver? It could be in Protection Mode. Is power button on the unit flashing red? If so, that's protection mode. It could be as simple as a speaker wire got crossed or cut but it could also be something internal.
Step 1: Label all wires plugged into the receiver so you know where to put them back.
Step 2: Unplug everything, including the power cable.
Step 3: Leave it unplugged for 10 minutes.
Step 4: Plug in *just the power cable*
Does it still click? If so, it's an internal component that's bad.
Does the clicking stop? If so, add one wire at a time, waiting 1 minute before plugging in another wire. Keep adding wires till the clicking comes back. Once the clicking comes back, unplug the last wire you plugged in. That wire has a problem. It could be the wire itself or the device connected to the wire. If it's a speaker wire, for example, it could be that the wire got chewed or cut, or it could be that the speaker got fried inside.
Mar 19, 2016 | Denon Audio Players & Recorders
My fax machine will send a fax, but I can't receive a fax?
The fax machine may be in secure receiving mode. The following is from the User's Manual section on Faxing. downloadcenter samsung com
Receiving in secure receiving mode
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Activating secure receiving mode
  1. Press btn_fax.png(Fax) on the control panel.
  2. Press Menu until Advanced Fax appear.
  3. Press the left/right arrow until Secure Receive appear and press OK.
  4. Press the left/right arrow until On appear and press OK.
  5. Enter a four-digit password you want to use and press OK.
    You can activate secure receiving mode without setting a password, but cannot protect your faxes.
  6. Re-enter the password to confirm it and press OK.
  7. Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
  1. Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
  2. Press the left/right arrow until Print appear and press OK.
  3. Enter the four-digit password and press OK.
    The machine prints all of the faxes stored in memory.
Deactivating secure receiving mode
  2. Press the left/right arrow until Off appear and press OK.
    The mode is deactivated and the machine prints all faxes stored in memory.
  4. Press Stop/Clear to return to ready mode."
Feb 10, 2015 | Samsung SF-650 Laser Fax/Copier
Why does "Protect" appear on my receiver before going out?
The receiver will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
if it is, then remove the speaker wires and connect them again properly. After disconnection g the speaker wires, unplug the receiver for 10 to 15 minutes. This will make the overload protection back to normal
Try this and let me know. I hope this would solve the issue
Thanks
Nov 10, 2011 | Audio Players & Recorders
Hello my sony audio/video control center #STR DE335 is in PROTECT MODE.. and i cant listen to it..can u please tell me whats wrong?
PROTECT display indicates that receiver got serious problem in output amplifier section and protection mode is activated to avoid further damage.
Output amplifier section should be tested by qualified technician to find out and replace defective part(s) to solve this issue. Local repair shop will do this job as it is not user level repair.
Thanks.
Apr 29, 2011 | Sony STR-DE335 Receiver
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
P8-Abnormality in outdoor unit.
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board.
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Jan 01, 2009 | Onkyo TX-DS939 Receiver
My phones need a puk code
if you enter the wrong pin code for 3 times your sim will get blocked ...
it will ask for the puk code ...
then you must call to the customer care of your network provider and you must tell them that your pin got blocked you want the puk code ...
they may ask for the details of your sim card be sure to tell it ..
then they will provide the puk code note it down and enter into it ..
your sim will get unlocked...
note :
if you enter the wrong puk code for more than 3 or 10 times the sim will get fully blocked if then you must contact to network provider shoppe....
Apr 02, 2008 | Nokia N73 Cellular Phone
Motor throtting
This error appears when the printer has worked for more than 1 hours continuous, and to protect the printer. Wait a few minutes for printer to cool and continue with your printing.
Jan 22, 2008 | Datamax I-4208 Thermal Label Printer
Protect?
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Jul 12, 2007 | Sony STR-DE197 Receiver
42 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
