Question about DHD NTX-2008 Car Audio Amplifier
Amp light flicking off and on
My Amp is hooked up to my car and when I turn the ignition key on the green power light on the amp flicks on then off straight away (hense not working). Does the amp have a shut down mode or is it stuffed?
    Problem Solver:
  • 11 Answers
That could be a few things i had that same problem check all ur wires make sure u have a good ground that was my problem
Posted on Jul 03, 2009
TV TROUBLE
i have vivitek 56 and it is flicking how do i stop from flicking
Nov 24, 2011 | Mitsubishi Televison & Video
I have a 2003 Impala and the "low tire pressure" light came on. I filled the tires and had two new ones put on. I got on the radio to reset it and everything showed up except "tire"...
The procedure must take place in less than 5 seconds. Turn key to on position. Flick light switch to parking lights 3 times & turn key off in less than 5 secs. Good luck!
Jan 28, 2011 | 2003 Chevrolet Impala
No picture - green light flicking on and off
Bulb light indicator flashes?Projection bulb use alot,an awile like about 1 or 2.The projection bulb must change it at end of it life cycles.
Apr 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Automatic car starter
Check the hood pin it is usually place by the battery make sure it is not bent or damaged. Then shot off the toggle shitch and disconnect the battery and reconnect it, turn the toggle back on see if it resets. Good luck
Aug 03, 2009 | 1998 Toyota Corolla
Cooling fan not working
check the solder joints from the fan to the board and if they are fine u will need to get a new fan
Apr 17, 2009 | Bob Mackie MACKIE M1400/M1400i Car Audio...
The power light flicking on and off.
sounds like either a bad earth or a bad remote signal.
check the earth cable for continuity - make sure that it has a good earth to the chassis of the car.
also check the remote signal cable that runs from the back of the head unit to the amp ~(use multi meter to check continuity).
Apr 09, 2009 | Pioneer GM-X334 Car Audio Amplifier
Flicking standby
Power supply is developing a problem sustaining voltage regulation and is programmed to shut down. Or it could be a bad OP-Amp on the interface board that's not closing when voltage is applied. Your tv needs servicing. You can send it too us or at your local tv repair shop for proper troubleshooting and repair.
Feb 11, 2009 | Samsung SP42P2S Television
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
DHD NTX-2008 Car Audio Amplifier Logo
115 people viewed this question
Top DHD Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
