Question about GE Washing Machines
Model and serial ge washer wwse5240g0ww am938099g
Doesnt wash after filling alot of times
Doesnt spin and pump alot of times
  • nergerauto Jun 28, 2009
    Your information was very useful
    I checked the filters-good
    I checked the water pressure tube and it was not the problem
    I checked the lid switch and if I shift the lid to the right it will start spinning/washing and move it back to the left it will stop spinning/washing.
    the contact just looks like a magnet or something...I tried wiping it of and/or bending the contact but it doesnt make a difference...It is almost like the contact is to far to the right but it doesnt shift or move...Is it common on this individual machine that they go bad? Or do you have that much detailed info on this machine?
    where is the best price or a wholesale price on a repair manual for my machine
    I used to use Johnstone Supply but they dont do appliance stuff anymore
  • 10,515 Answers
This is common in most of the GE and KENMORE models.A good detailed procedure, How to check Lid Switch is Described below :-
http://www.acmehowto.com/howto/appliance/washer/check/lidswitch.php
You can also order Lid switch from :-
http://www.repairclinic.com
Part number for your model :-
The part number for the switch is: WH12X10334.
Regarding service manual,
As such, for your model is not available at this moment with any of the online vendors.
You can look at one of the most selling Repair Manuals :- ( Common for most of the GE machines ) :-
http://www.repairclinic.com/SSPartDetail.aspx?PartID=311971&PPStack=1
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jun 28, 2009
  • 2,071 Answers
Your washer does not wash and not spin then there three common symptoms causes the trouble. First the filter screens, secondly the water level switch and lid switch. Before checking the filter screens, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. The hot and cold water from your home connect to the water inlet valve on the back of the washer. In each end of the water supply hoses there may be a filter screen to catch debris and prevent it from damaging the washer. The water inlet valve also has filter screens. If the filter screens become clogged, the result is low water pressure, no water or the wrong water temperature. The water inlet valve can be identified by the water hoses connecting to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting adequate water pressure and to clear any debris from the line. Inspect the filter screens on both of the hoses and the inlet valve for debris build up. If you find any debris, clean it out. The screens in the inlet valve are not removable so use caution to avoid damaging them. If you are getting good water pressure and you find no build up of debris, then the inlet valve itself may be faulty. The water level switch (aka pressure switch) senses the water level in the wash tub. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch. A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub.The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch.The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multitester. Set the multitester to the ohms setting X1. It will be necessary to test each of the three possible pairs. Lastly the lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing. There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Good luck? Regards: VOTIT
Posted on Jun 27, 2009
My GE washer fills, does not agitate and then empties but does not spin.
Please provide a Model and Serial number and repost. Makes it easier for the Techs to determine possible issues. Depending on the model it sounds like it is a motor coupling, which is a cheap part but a bit of labor and wrangling to change. Thanks.
Sep 24, 2010 | GE Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Model: WWSE5240G0WW Tub does not spin but can hear motor running. Rest of cycles appear normal. Nut underneath the agatator is tight.
Does it drain? If not your pump is bad. If it does drain you need a belt if it is a belt driven washer.
Oct 17, 2009 | Washing Machines
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Washing Machines Logo
121 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
