Question about Minolta Maxxum 7000 35mm SLR Camera
The batteries leaked in the battery case, how do I clean this? I have a Minolta 7000. White residue on the side of the camera also.
    Problem Solver:
  • 15 Answers
Remove old batteries asap and (use gloves) dry the the dirty with cotton swabs, discharging them as they get wet. Apply commom kitchen white vinegar with the help of a small paintbrush. Repeat 2-3 times. Dry with cotton balls. In general this helps. Be aware that the contacts coat (nickel, I suppose) have been gone. This demands a constant check (every week or so) to maintain them clean. I had this problem in an old Olympus Camedia C2000Z and the above procedure was effective in it.
Posted on Jun 28, 2009
  • jmp101694 Dec 01, 2010
    Worked like a Charm on my wireless mouse that had the same problem. thanks!!
HELP ON SCREEN
Try fresh batteries. Check for corrosion from leaking batteries on contacts and where battery compartment snaps onto battery door. Clean corrosion if there. If you do not measure over 6 volts at the two metal contacts on the door, then this is probably the problem (very common). Otherwise, failure of motor, loose screw in transport gearing unit on top
Apr 03, 2013 | Minolta Maxxum 7000 35mm SLR Camera
The battery in my Minolta Maxxum 7000 died while rewinding. I replaced the battery, but nothing happens and the rewind-button/slide is stuck. How do I reset this slide, so I can rewind my film?
Sorry to hear you're having troubles with your Minolta. First thing I would do is make sure that the batteries you put in our good and that you do have power coming out of that battery box. He didn't mention whether the batteries had corroded or if there had been any corrosion previously. The rewind button on this camera will not reset until the camera again advances. In other words it is an automatic release on the camera fires the first time after a rewind. So as an beginning answer to your question I would check the batteries again make sure that all contacts are absolutely clean and as you may have noticed the battery boxes on the Minolta do pivot. The contacts under the pivot points also have to be clean. If you checked all of these issues and you're still having problems please feel free to e-mail me at, Dave@advancedcamera.com.
Thank you good luck
Aug 10, 2011 | Minolta Maxxum 7000 35mm SLR Camera
Wht battery and where it is located in minolta 7000 Program Back 70
The Battery in Minolta Maxxum 7000 35mm SLR Camera is NP-400 lithium-ion battery.In the program it is located in the located inside
Aug 28, 2010 | Minolta Maxxum 7000 35mm SLR Camera
My Maxxum 7000 won't power up with new batteries
Good Afternoon,
it's very possible that you're still having a battery supply issue. When the battery compartment is tipped out to replace the one inside AAA battery you'll notice a small sliding contact it's very easy to overlook. I would suggest cleaning always contacts again using vinegar. Then wash it off completely, dry well and then reattach your batteries and try it again. Remember that the battery box has to be firmly in place and the retainer screw completely screwed in to activate the switch on the side of the camera to allow the camera to function. If you try this and it again fails it's also possible that your particular maxim had a used metering link installed just underneath the battery compartment that metering link can also fail when it does get acts as a crime or refuse and the camera won't function. The last thing I would check would be your primary backup battery which is located under the stainless steel plate that your batteries set up next to on the side of the camera it's held in the position by six screws. This is a 2025 battery and is easily replaceable. Please be sure and check your power supply first as this is 90% of the problems that we see in the shop good luck if you have any other issues feel free to contact me directly at Dave@advancecamera.com
Jan 15, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Minolta 7000 camera.Where can I replace the embedded battery?
most camera shops will be able to help you . Minolta are still available
Jul 31, 2009 | Photography
Where can i buy a battery holder for a minolta maxxum 7000.
try a camera repair shop for a good used one, no new parts are available. or try ebay. you may have to buy a complete 7000, then keep it for parts.
Jun 22, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Need Minolta Maxxum 7000 battery holder
hi, I have a spare battery holder for minolta 7000 model, if you are still interested.
Best regards
Bob
Jun 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Maxxum 7000
The lithium button cell is only a memory backup for when the main power pack is off the camera. It allows the camera to retain the number of exposures, asa setting, etc. You problem may lie in the battery holder. The BH70 was prone to corrosion at the contacts and the pivot points where the part that holds the batteries to the side plate with the retaining screw. It is possible to remove the batteries from the holder, then carefully separate the two pieces by popping one end enough to allow the pivot pin to slide past the notch. Use a hard eraser to clean all of the metal points (pivot contacts and the springs and plate in the 4 cell holder.
Jan 26, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
138 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
