LG Netbook x110. The screen doesnt work
I have an LG Netbook x110. The screen doesn't seem to be working when I start it up. If I keep on putting it on and off, at some stage it starts up normally...What do you recommend I do? Thanks
  • 32,281 Answers
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 28, 2009
Dear Sir,
I have LG Net Book Model # X110. A few days back it was dropped on the floor and LCD working the way half of the screen visible. Soon after i tried to press Fn + F7 to use an extenal monitor which did not work we also tried to press Fn+F1.......F12 but as a result we got half of the screen black which was visible earlier.
Please advise how to fix the problem or i use an external monitor with my LG net book.
regards
Salik
Posted on Feb 24, 2010
Lg x13 screen issue? no display.
Well, the good news is you pretty much trouble shot the issue. If you plug it into the monitor and see your desktop without any issues, the video card in the notebook is still good. That's the good news. The bad news is your laptop display is bad. It sounds like your back light is failing. You can purchase another one; but it is much easier to replace the screen as several things can go wrong trying to replace just the back light. There are plenty of YouTube videos on how to replace the screen yourself if you're daring enough, or take it to a computer repair store and they can replace it for you.
Oct 27, 2014 | HQRP Car Charger 12V DC Adapter...
My 900hd netbook won't boot
as soon as you turn your netbook on, keep tapping F8 until another screen pops up, then select start up repair, If no problems found and doesnt work. repeat the process but choose safe mode with networking, then click start and shutdown, try and reboot as normal, If doesnt work. Select safe mode with networking once again by repeatedly tapping F8 as soon as you switch on your netbook. Please download tdsskiller.exe (exe not the zip) to your desktop using this link at the end. Once downloaded please double click to install. Once installed open and run a scan, once scan complete, select cure and then rebsart your system, start system normally and that should solve the problem http://support.kaspersky.com/viruses/solutions?qid=208280684
Please rate if helpful, thanks. P.S tdsskiller is a freeware and will not cost you a penny.
Mar 10, 2011 | ASUS Eee PC 900HD Netbook
Where can i download the recovery software for my LG x110
Thanks for visiting FixYa!
If you need to download the recovery software for a LG x110, click on this link: http://thefilestreasury.com/?search=lg+x110+recovery+cd&wmid=143&hl=US
Feb 17, 2011 | LG Cell Phones
I full signal strength from my rounter but wont connect
This could be due to wrong DNS settings or IP Address. You will need to go in to your network connections by doing the following: "Start, "Control Panel", "Network Connections" and then right click on your wireless connection and select "Properties", then when the new window opens scroll down to something called Internet Protocol (TCP/IP)
Open this by clicking "Properties" then adjust the settings as follows:
- Obtain an IP address automatically
- Obtain DNS server address automatically
Then configure your router to assign the IP Address and DNS Settings automatically and your internet should work.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | D-Link Computers & Internet
The clip holding one of the keys has broken where do i find replacements? its a lg netbook x110
You'll have to purchase a new keyboard assembly. Follow the link below and put in your model number. You can purchase directly from the manufacturer.
http://www.lgserviceparts.ca/
Dec 31, 2009 | Computers & Internet
Cursor frozen, won't respond to touchpad LG X110
Press fn+f9, this is a mode for locking and unlockig touchpad
Jun 04, 2009 | Computers & Internet
Danish keyboard setup for LG x110
just setup the language from the control panel /regional and languages...select languages add ...and select danish ...you migh leave english on and ...select them as needed..cause sometimes its issual ...if not remove english ...by select it ..and delete
Mar 12, 2009 | LG LW20-EV Notebook
LG Notebook driver upgrade
Install a program called Everest and identify your wireless device. Google search this device.
Option 2: if you have the XP driver for the device, try a force install. some XP drivers can work in Vista.
Feb 25, 2009 | LG X-Note LM50 Notebook
Computers & Internet Logo
1,286 people viewed this question
Alun Cox
David Payne
David Payne
