Problem with Samsung S760 Digital Camera
every time i turn off my camra the lens wont go back in
the lens wont go back in and the pics are blury..except whein i put it close to something..like my hand, if i put it up close to my hand i can see every line and scrach..i need help!!
Posted by avatar on Jun 27, 2009
Suggested Solution (2)
Hello This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended. Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore. Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
  • by Author image Motoi Bogdan Over a year ago
Source: Camras Broke
Was this solution helpful?
No
Yes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
  • by Author image Ty Price Over a year ago
Source: MY CAMRA WONT TURN ON AND MY LENS WILL NOT CLOSE
No
Yes
Tips for Helping jamie_scheff With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all Samsung S760 Digital Camera Problems
