I recieved the following error massage if I try restoring my LapTop %1 is not a valid win32 application problem windows vista
  • heashoor Jun 28, 2009
    Thank you for your help. I have problem in copying the file in system32 folder it wont work
  • 428 Answers
If it comes up while restoring, for rstui.exe(restore utility), it may be due to a virus infection. Scand your system and see. Run this utility in safemode. To go to safe mode, Reboot the machine and press F8 before the Windows Boot screen appear. Then go to safemode.
Do system restore from there. If the utility is corrupted what you have to do is copy rstrui.exe from another computer, paste it to system32 folder.
Copy it from an exactly similar OS version.
If you have problems, go to device manager and go to event viewer
and check the categories, System and Applications for related errors.
To get to devuce manager, Rclick on My Computer Icon and Selact Manage.
Thanks
If this solution helps you plase kindly rate this answer.
Good Luck.
Posted on Jun 28, 2009
  • Tharinda
    Tharinda Jun 29, 2009
    When u boot, press F8 repetitively and get the safemode. Select Yes from the dialog box. Then go to system32 and Paste it there. Make sure u clean all the temp files Do a disk cleanup) and remove al internet temp files and temp files from there and from browsers by getting Tools->Internet Options.And make sure ur Root partitions does not contain any .bat or .com viruses. Go to My Computer->Tools->Folder Options->View->Hide protected operating systems(recommended) and remove the tick. Remove the other options tick above also. And set the options to see the Hidden files. Remember u have to be an Admin to performe these tasks. Then do OK. Then go to C:? and check whether u can see files such as boot.ini, folders such as System Volume Information. Ifu can't see anything, that means there is a virus infection. MOst probably viroot or dotnetfx.
Am trying to install vista on my windows xp-sp2 but it gives "spinstall is not a valid win32 application......how to install then???
Are you doing a Dual-Boot? With a Separate Partition on the Primary HDD? I'm a bit confused? Are you doing a install on the Primary HDD and installing over the Win XP? Did you format the HDD? Or on a second HDD?
Mar 20, 2013 | Microsoft Windows Vista Ultimate Edition
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
I cant format my window because when i click that will give me that ''not a valid win32 application''
Exactly what are you trying to format? Usually you cannot/don't want to, format the drive you are working on? "not a valid win32 application" usually means, that the program you are trying to run, is a DOS based program. Formatting is usually done via DOS.
Feb 26, 2010 | Microsoft Windows Vista Home Premium...
I recieved the following error massage google updater.exe is not valid win32 application
you probably tried to run google .exe.. from start ..run ..and cause this is not a windows execution it can not be run from there ...thats all....if you want to update the gmail or something like that you have to download a valid execution and run the installer..
Jan 17, 2010 | Computers & Internet
Win32?whats that?
It is telling you that the file you have downloaded is invalid. It probably means it is corrupted during the download process.
I'm not sure what you are downloading but have you tried AVG free edition?
You can download it here
http://free.avg.com/ww-en/download?prd=afe
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
*.pps is not a valid Win32 application
Right click on the file and go to open with then select the Powerpoint Viewer 2007 and check the box making it the default.
Jun 13, 2009 | Computers & Internet
Hi, recently i had virus in my comp called win32.worm.autorun.MQ i restored my windows through restore after cleaning up when i click on my drive it gives me error saying "resycled\boot.com is not valid...
This is a solution i found at another site that i think could help you with your probem
Hi
If you still need help with this please do following:
Download and install TrendMicro HijackThis
* Once installed open HijackThis by clicking Start > Programs > HijackThis and click the button labeled
Do a system scan only
* Click the scan button in the lower left hand corner of the interface and HijackThis will quickly scan your system.
* Once the scan is complete the scan button will now read save log. Click this button to save the log file to your PC. Once you select where you would like to save the file it will open in your systems default text editor. Typically this application is Notepad. Post the log here.
The link:http://www.techsupportforum.com/security-center/virus-trojan-spyware-help/hijackthis-log-help-inactive/306207-resycled-boot-com-not-valid-win32-application.html
Please let me know if you need more help with this problem
Jan 06, 2009 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
Alun Cox
David Payne
David Payne
