Question about JBL CREATURE II Computer Speakers
Working on tv/playstation 2
Hi, I'm trying to get my speaker/woofer system hooked up to my tv and/or playstation 2. however the green "woofer" cable doesnt want to plug in anywhere??? i have succesfully plugged the system into my laptop in the past using the headphones plug socket. However this kind of socket doesnt exist on my tv nor the playstation2???? do i need to buy something???? or is there a solution i have not thought of. thanks!!!!!
  • 328 Answers
You can easily buy RCA conectors and splice them. Remove the 1/8 plug from the speakers and strip the ends and add the RCA connector. I am not so sure of what it would sound like but the ohms may be different.
Posted on Nov 06, 2007
  • Lyle Siemens
    Lyle Siemens Nov 06, 2007
    How in the world was my solution not helpful?? Do you not want to do this????????
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Yamaha rx-v2500 receiver how to hook up speakers
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
I have a coby CSP96 speaker system. it said on the manual online that i found on the site that there should be a volume control on top of the sub-woofer but there isn't one there. i can only...
I am having the same problem. I also have the combo dvd and theater system. I also read that the sub woofer is supposed to have a volume control on it but its not there. The only way to control volume is to connect to coby dvd player. This dvd player is beyond terrible. DVD looks bad and sound is miserable. I hooked up xbox 360 to my samsung 52 inch, then on the outputs of my tv into the inputs of the "TV" section on the Coby Sub woofer. At this point great sound quality comes from the xbox and all speakers, but the volume is uncontrollable and is blasting loud. Tv volume control does not work either. I am stuck like chuck and have not found a solution. This has to be one of the worse purchased i have ever made because i am forced to use a terrible DVD player just to get some sound through the speakers. I dont understand why on the speaker systems you buy without dvd combo has a volume control on subwoofer, but on the combo subwoofer doesnt have it. Just terrible. I will continue to look online and try and find a solution other than smash it to bits.
Oct 19, 2010 | Coby CSP-94 Speaker
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Dec 13, 2009 | Audio Players & Recorders
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
Plug red and white cables into woofer ports that are red/white
Plug purple lead into front of woofer to input port
green goes into accessory (green) port on back of computer
elbow shaped 2 prong leads go to speakers in back
DC power goes into front of woofer marked DC input
Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
Hook up z-5500 suround to a tv
The Sony has (
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Oct 22, 2008 | Audio Players & Recorders
Connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
JBL CREATURE II Computer Speakers Logo
82 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
