Question about Xerox XC356 Copier
There are black stripes on the paper on the dark setting
  • 313 Answers
The black stripes are probably due to drum wear as you are putting more density to the picture.. you could try and clean the optical mirrors if you know how the service proceedure goes adn the n the charge and dev settings could be ajusted if you need tolighten the image.. if your not amiliar with working on machines I would suggest getting it serviced by a tech
Posted on Jun 28, 2009
My HP printer 1022 laser jet is making black stripes at left corner of the paper
This could happen due to
1. Worn wiper blade
2. Worn Drum
3. Worn PCR
above 3 are inside the toner, if you know how to replace them replace or install a new toner, if the problem still persists you have to check the fuser or contact a technician..
Jun 20, 2012 | HP LaserJet 1022 Printer
How can i hook up my pioneer deh-1600 cd player into my car
Hello! First the DEH side:
  • Gray - Front Right +
  • Gray w/Black Stripe - Front Right -
  • White - Front Left +
  • White w/Black Stripe - Front Left -
  • Purple - Rear Right +
  • Purple w/Black Stripe - Rear Right -
  • Green - Rear Left +
  • Green w/Black Stripe - Rear Left -
  • Blue w/White Stripe - System Remote Control (Ant)
  • Black - Ground
  • Red - Switched Power
  • Yellow - Constant power
Vehicle side:
constant power Orange
switched power Yellow
ground Black
Illumination Gray
Antenna Dark Green
RF Light Green
RF - Dark Green
LF Tan
LF - Gray
RR Dark Blue
RR - Light Blue
LR Brown
LR - Yellow
Guru...saailer
Jun 04, 2012 | 2002 Pontiac Grand Am
What do the wiring colours mean?
This is the typical configuration for the wires coming from a car stereo.
Right Rear Spkr (-) = Purple w/ Black Stripe Left Rear Spkr (-) = Green w/ Black Stripe Right Front Spkr (+) = Purple Gray Left Front Spkr (+) = Dark Green White Right Rear Spkr (+) = Blue w/ Orange Stripe Purple Left Rear Spkr (+) = Brown w/ Blue Stripe Green Power Antenna/Amp = Blue +12 Volt Battery Wire = Yellow +12 Volt Ignition Wire = Red Right Front Spkr (-) = Gray w/ Black Stripe Left Front Spkr (-) = White w/ Black Stripe
Jul 07, 2009 | Car Audio & Video
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Where are the cam sensor and crank sensors located on my car?
Crank Sensor: Passenger side of transmission just to right and above the differential cover. Has 3 wires:
Light Blue/Dark Blue stripe - Signal
Dark Red - 8v supply
Black/Light Blue stripe - Ground
If the car runs or cranks, you can test this sensor by first checking for power on RED wire with key ON. Should be 8-9.5 volts DC. Furthermore, connect a dwell meter to the signal wire by probing the back of the connector. Dwell reading should be 49-51%. If not, its likely bad.
If you remove the sensor, you MUST replace the paper spacer on the end of the sensor or you risk damaging the sensor or even the torque converter drive plate otherwise. Also make sure O-ring is in good shape and positioned properly.
Cam Sensor:
Facing Engine, it is on the driver side timing case housing, on top of the round part, just to the right of the fuel rail pipe where there is a capped fuel valve.
Has 3 wires:
Tan/Yellow stripe - Signal
Testing is same as for Crank Sensor.
May 14, 2009 | 1994 Dodge Intrepid
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Xerox XC356 Copier Logo
227 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
