SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
SOURCE: Solve error 5100.cannon pixma 145 error always out # 5100
5100 error is a carriage error. Could be caused by the carriage unit, timing strip, logic board or carriage motor. Check that nothing is obstructing the carriage from moving freely and that the clear timing strip is ok.
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
SOURCE: cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
SOURCE: what is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
