Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Picture & sound go off for 1-2 minutes, then return.
Sony KDSR50XBR1 RPLCD - Picture and sound go off after set has been on for 5 minutes. Standby light blinks rapidly, then sound and picture return. Repeats in about 3-5 minutes. Checked all the input connections (cable, DVD); did a reset- nothing helps.
  • 73 Answers
If the green light starts flashing after losing pix and audio and then becomes solid and pix and sound return.I would suspect lamp.
Posted on Jul 14, 2009
    President:
  • 1,077 Answers
The most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
TV has good picture sound and picture keep going off up to 2 minutes then returns. Its a sony LCD projection TV 65"
The tv "LAMP" LED light indication staying on or blinking on the front tv bazel frame?The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on and watches like 4 or 5 hours daily?Yes to all of these,mean the tv projection lamp life are ending.Require a new projection lamp for the tv.
Jan 14, 2011 | Sony Televison & Video
My TV picture has a yellow color all the time. Even in Black & White. It is Black & Yellow.
sounds like a bad optical block this affected a lot of sony tvs and is a expensive repair try contacting sony they might help.
Feb 03, 2010 | Sony KDSR50XBR1 50" Projection HDTV
I have a sony kdsr50xbr1 screen turns off after 15 min, there is still sound but the screen is essentially blank. Sometimes there are bars on the side of the screen for a second. The the status light...
Hi!
Please try disconnecting all the cables from the TV then reconnecting them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then the projection lamp needs to be replaced.
Aug 27, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Aug 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV loses picture/sound after 5 minutes then comes back. Repeat
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2017 | Sony KDSR50XBR1 50" Projection HDTV
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
243 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
