Question about GE WSM2780W Stacked Washer / Dryer
Washer started to smoke on the spin cycle. The belt is still on but Ifound broken pcs. with grease on them sitting on the tray thats abovethe belt. looks like they came from where i would think bearings wouldbe located but these pcs. are plastic.
    Problem Solver:
  • 14 Answers
Encountered the same problem. You can unplug the unit, remove the front panel of the washer and then slowly remove the belt. The replacement belt is easy to put back on. Finding a belt on the internet for under $10 is easy - just search for a belt with part number 134161100. Potentially the plastic pieces are from the damaged transmission. Replace the belt first to see if you can keep using the unit. If the transmission is damaged it is a bit expensive to replace and difficult to do yourself. I'll keep you posted if I have to do the same to my unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Posted on Aug 14, 2009
  • 4 more comments
  • ChrisIngram.net
    ChrisIngram.net Aug 14, 2009
  • ChrisIngram.net
    ChrisIngram.net Aug 18, 2009
    I've got same issue. First had to remove and replace the washer belt (order part # 134161100 from google or ebay), arrived in two days and noticed busted plastic pieces and two semi-circular metal bearings that would have fit into the bearing. Now I've got to:
    1. find that bearing part number
    2. empty the washer and dryer and put tip it over gently to place it on its back
    3. remove the bottom to replace the bearing
    4. re-assemble all parts then stand unit back up.
    thanks,
    Chringram
  • ChrisIngram.net
    ChrisIngram.net Aug 24, 2009
    Follow up to this post:
    IF REPLACING THE BELT DOES NOT WORK (read on)
    Troubleshooting
    Step 1: Keep the front panel of the unit off and run the unit in a normal wash mode. You can do this without filling up the wash tub with water by simply rotating the WASH dial to the proper setting (eg. RINSE). Be very careful as the moving parts could cause injury while the front panel of the washer is removed and the tub is turning.
    Step 2: Watch to see if the belt is still slipping and the tub does not turn. If it rotates properly, then congratulations, you have fixed your problem with a new belt. If the belt still slips, ... proceed to step 3.
    Step 3. Some web sites (and the user guide) say that the 'tension spring' may not be working. I don't believe this is the case. Upon closer inspection take a look at the 'transmission' which is the large metal part that rotates the tub. Unplug the unit and using your hands, see if you can rotate the tub simply by turning the transmission part. Turn the transmission in both directions. If you see that it gets STUCK from time to time, then the transmission needs to be replaced due to some worn bearings.
    NOTE: From here you must first consider three things:
    A. Do I want to get into a major repair with this washer, or simply purchase a new stack set?
    B. Should I call a GE repair guy and have him replace the transmission?
    C. Should I do it myself?
    HOW TO FIX (If you chose "C" above):
    FIX Prep Step 0. Gather a bunch of old towels around to clean up any water that spills
    Step 1. Empty the wash basin and disconnect all external hoses, gas lines etc.
    Step 2. Arrange the stack set so that you can lay it down on its back. Always good to have two people to do this step.
    Step 3. Disconnect the tub basin springs and all electrical wires from the motor (this is easier to do while the unit is laying down; some channel lock pliers come in handy)
    Step 4. You can stand the unit back up for this step. Slowly remove the tub basin from the unit, and position it upside down.
    Step 5. Remove the transmission (requires standard socket set)
    Step 6. Order the Transmission Assembly Kit online (I found mine at SEARS PARTS ONLINE, and when I called to check if they had it in stock, the customer service rep even gave me a code for 10% off the online order - not too shabby and makes me want to go back again. Great support service!)
    Step 7. When the part arrives, re-assemble everything and test.
    REORDER PARTS INFO
    Tub Assembly Part Number: WH38X10014 (aka. GE part # 1603 on their 'break away' diagram)
    Available on SearsPartsDirect.com
    Note: The GE Parts people were unfortunately not helpful at all during this troubleshooting. In fact, when calling their support line I was told that they would not even sell me a transmission because I was not a certified repair man. The GE service rep was insistent that I could not find the transmission anywhere else except through them. Although they have nice diagrams of all the WSM2780 machine parts on their geappliance.com web site, don't look to them for any extended repair support.
    You can contact me if you have any questions.
    Thanks, Chringram
  • ChrisIngram.net
    ChrisIngram.net Dec 08, 2009
    Need some clarification first:
    a. with the unit unplugged and the front cover of the washer off, can you rotate the washer manually with your hand in both directions?
    b. among the plastic pieces did you find any silver ball bearings?
    Potential issues:
    If you answered "yes to A" and "no to B" then a belt replacement might fix it for you. I can get you the part number and a web site online to order it from.
    If you answered "no to A" and "yes to B" ... then the repair is more complex and requires a transmission replacement. I've actually done this and can be tricky but is possible by the handy home owner with some patience.
    thanks,
    Chris I.
  • ChrisIngram.net
    If the WASHER BELT is burnt or broken or the WASH TUB is not rotating properly.
    FIRST CHECK THE BELT:
    Remove and replace the washer belt (order part # 134161100 from google or ebay), arrived in two days and noticed busted plastic pieces and two semi-circular metal bearings that would have fit into the bearing.
    Troubleshooting
    REORDER PARTS INFO
    Thanks, Chringram
  • ChrisIngram.net
    Troubleshooting
    REORDER PARTS INFO
    Thanks, Chringram
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
My washer squeals during spin cycle model frigidaire fex831cso. Sometimes it does it on the highest speed it reaches other times at slow speeds. One thing that is constant is... once it starts squealing...
The belt on my was the culpret. The washer belt has a spring loaded idler. Unplug power and move the idler off of the belt and use a spring hook or longnose vice grips to pull spring out of slot and into the next slot closser to you. There are 5 slotts. Push idler back by hand and put belt back on it. Your done. The transmission just spins as a unit in spin cycle, it does sit on top of a bearing,but that didn't seem to be the problem. If the belt tension doesn't fix it, put some grease and oil in the bearing or replace it.
Eventually you will need a new belt so order one now.
Jan 27, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Kenmore 94802 washer belt overheats, smokes, and melts
sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Apr 08, 2008 | Kenmore 94802 Front Load Stacked Washer /...
FGX831CSI Stakable
ok possiable not tranny problem no just take two screws out of the bottom panel of washer and pull down on panel proably a burned belt or broken spring on belt idler pully
Mar 30, 2008 | Frigidaire FEX831CS Top Load Stacked...
GE WSM2780W Stacked Washer / Dryer Logo
158 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
