Question about Nintendo Rock Band for Wii
Both symbol wires broken
One of my wires detached itself from the little L-shaped plug that goes into the orange symbol. On the yellow symbol the wire (non plug end) is frayed but still attached. Suspect I need an electrician.
    Problem Solver:
  • 6 Answers
I agree withe you about geting an electricin but before you get him maybe something wrong with the symbol wires or the television
Posted on Jul 10, 2009
What is the blue wire that plugs into the fuel pump on a 2000 Lincoln town car with a 4.6 motor
At the fuel pump, pink with lite blue tracer is voltage.
I looked at the fuel pump relay , there are two lite blue wires with orange tracer. I divide the relay into two sides, load side, has the arm with arrow head, that lite blue wire is voltage, you can see the fuse. The control side of relay is that coil looking symbol, that lite blue wire is ground controlled by computer.
Dec 09, 2016 | 2000 Lincoln Town Car
Where does the orange silver wire go from the horn relay
is it a spare wire ? the wires from relays are generally all used so it will either go to the switch,horn itself ,earth ,live , usually the earth is black ,the power is red and the switch/ignition live is yellow so i would say the other colour goes to the user in this case the horn, could'nt actually find a orange/silver wire on honda wiring diagram but there is orange/grey hope this helps
Apr 24, 2014 | 2002 Honda Civic
I am trying to convert a three wire prong to 4 on my whirlpool dryer.
Inside the back of your dryer is a strip where the electric cord fastens on, behind a squarish panel about 5" X 5" sort-of.
There should be 3 screws/nuts in a row of the cord to hook to.
The right and the left screw/nut is HOT, for the black or red wire on a 4 wire cord. It does not matter which gets black and which gets red, they are both HOT. These wires are attached to the FLAT lugs on the plug end of the cord, NOT the "L" shaped or the round lugs.
On a four wire cord, there are also a white wire and a blue or green wire. These are both ground wires. The white wire goes to the middle screw/nut on the 3 connection bar of the machine, and the blue/green wire goes to the body of the dryer itself. (Use one of the little screws along side the opening for the wire.) The white wire goes to the "L" shaped lug on the plug, and the green/blue wire goes to the round lug of the plug.
Be blessed.
Jun 23, 2013 | Dryers
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
I need to know which wires are what on a Clarion TVX5653 for the main(power) harness. There are 7 wires colored as follows red, yellow, black, blue, blue/yellow stripe,orange, orange/white stripe. Thank...
red is for pawer that goes to the fuse panel
black is for the ground
yellow is a hot wire that goes to the main power or battery it should have a fuse in the line
blue is for power antenna if u need
blue and blue yellow speakers same with orange ,orange/white
Dec 13, 2010 | Car Audio & Video
How do i connect a telephone wire to an rj11 plug. What is the order of the wires for us telephones.
dialtone should go on the green and red wires of the jack for 1 line service, yellow and black for a second line.
Depending on the type of wiring that your dealing with the color code can change. if your wiring has white wires with little dashes of color on them then the code is:
green = white/blue (mostly white with blue dashes)
red = blue/white (mostly blue with white dashes)
black= white/orange (mostly white with orange dashes)
yellow= orange/white (mostly orange with white dashes)
Oct 23, 2009 | Lands Phones
Hi,can you help??the wire that connects the yellow symbol is broken completely off the black little thing that goes into the slot. the actual wire is coming out and i stuck it together with sellotape and...
im sorry to tell you this but you will have to get a whole new drumset because nobody sells just a yellow symbol. (this has happened to my friends before and they had to buy new sets.)
Feb 01, 2009 | Buck Guitar Hero World Tour for for Xbox...
I had guitar hero since xmas and yellow symbol not working
How did you break the wire?
The best I can suggest is that since the drum kit is still under warranty, take it back to the store you bought it from and get it replaced. Be sure to take of the selotape beforehand since it will look like the drum kit has been tampered with.
Red wire missing
the power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Nintendo Rock Band for  Wii Logo
103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
