Question about Fisher and Paykel IWL12 Top Load Washer
What is error code 130 fisher & Paykel intuitive eco IW812 ?
    Master:
  • Fisher and P... Master
  • 713 Answers
The R.P.S or rotory postition sensor is faulty or the connections are corroded
Posted on Nov 20, 2017
SOURCE:
  • 34 Answers
SOURCE: service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Posted on Aug 03, 2009
  • 34 Answers
SOURCE: fisher@paykel Intuitive eco comes up with code 130
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
  • 713 Answers
SOURCE: fault code 130 - fisher and paykel intuitive iw812
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
Posted on Aug 04, 2010
  • 251 Answers
SOURCE: Fisher & Paykel Washing
Hi - Faults 130-136 means there are some serious comm problems - motor stalls etc. The most likely cause would be the RPS Senor - has failed or loose, corroded, bad wiring connections.
This is under the machine - tilt on its back, remove the center round rotor has magnets on the inside be careful it stays clean. there are 4 bolts in the middle - remove to get stator off with all the copper wounded contraption, remove the wiring - not to worry too much but note on the stator Y_B_R relates to colours on wire harness, note also the harness & RPS component. replace this assemble & should work fine unless the controller is a dud.
95% of the time this is your culprit.... Part # 438515P I think for these range - pays to check 1st - You need to quote the Product nuber as this is critical to the components under the hood if you get my drift.
Posted on Jun 16, 2011
tng15606
SOURCE: fisher and paykel intuitive eco washing machine
intuitive ECO Model IW811 display error code 49...any one can help me
Posted on Apr 28, 2012
My washing machine IW812 has fault code 37.Could explain what that is please?
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
Nov 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco w.machine showing error code 130 and sometimes 240
switch the power off for a little while minute or 2 & turn it back on and press the power button and pstart the cycle again.
Apr 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel IWL12 Top Load Washer Logo
968 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
