Question about Hayward 1.5 Hp Northstar High Performance Pump
Hayward Matrix Power Flo
Where is the button to change discharge from vertical to horizontal???
On the right side, usually opposite the discharge. You may need to use a butterknife of flat head to push it in; push in and turn.
Posted on Sep 04, 2009
    New Friend:
I was not sure that was the button. I pushed the button with a screwdriver and it allowed the discharge to turn. The button to twist the power flow matrix is camouflaged very well. It is on the right side if you are looking at the pump from the wire/motor end, or on the left side of the pump housing if you are looking at it from the strainer end. it is at 9 o'clock on the pump housing if you are looking at the pump from the strainer end. It is right where the metal portion of the pump meets the plastic portion of the pump. It did not seem to lock in place very well though.
Posted on Jun 11, 2013
Removing the lid from a hayward power-flo matrix
Too Much Pressure????
Are you trying to remove lid when the pump is on? NO, NO, NO
If not, then good! If you have valves before and after the equipment, then close them. Then remove the small 1/4" drain plug to empty the pot. Then try removing the lock ring and open it up.
Jul 13, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
How to replace seal on hayward power flo matrix?
if seals leaking ruining bearings next to go replace whole unit
Jul 21, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
I am installing a 1592SP Power-Flo Matrix pump and I cannot seem to press the positioning button (it does not depress) to rotate the discharge port. I have taken off the strainer housing, but no matter...
I just went out and did mine. My button didn't depress at all at first. While trying to push the button in, jiggle the discharge both ways; the button will move in and the housing rotates very easily.
Gary
Aug 31, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Where is the button located on the pump housing to change the position of the water discharge?
I just checked on mine...actually had the discharge move a bit.
Looking from the motor end, on the right side where the motor meets the plastic pump discharge housing there is a square tab about 1/2 inch x 1/2 inch. Push that tab in using your finger while jiggling the discharge housing. It will click in and the discharge (and inlet) will rotate and click into the next position.
Gary
Jun 26, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Where exactly is the positioning button to change the discharge position? Thanks, Ed
In the plastic ring attached to the front of the motor. It looks like this:
John
Aug 23, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Hayward 1.5 Hp Northstar High Performance Pump Logo
251 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
