Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
Had inlet error code so Changed inlet valve and hose assembly. Unit operated ok for a short while and stopped dead. Just the salt light flashes rapidly now and no operation. Tub remained full and no activity in machine pump or wash motor. Checked for water in tray below and non exists so no leak. What is this error?
    New Friend:
  • 4 Answers
The drain hose may be clogged. Most of the times the clogging occurs at the connection with the drain pipe under the kitchen sink.
Posted on Jul 07, 2014
SOURCE:
Rotu
  • 175 Answers
SOURCE: Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Posted on Oct 03, 2006
gwshaw71
  • 83 Answers
SOURCE: Drain pump runs continuously
Which model do you have and is there any fault codes showing on unit? I have all of the service manuels for miele products.I am factory auth. for service on miele.
Posted on Feb 24, 2008
gwshaw71
  • 83 Answers
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
  • 3 Answers
SOURCE: Intake/Drain Error
I cleaned out the drain pump and non-return valve on my Miele G658/858 and that fixed the problem. The G841 may have similar parts. It's easy to do. In order: 1. Turn off washer. 2. Remove the triple filter (the basket on the bottom of washer with the little handle. Turn the handle and remove) rinse out and set-aside. 3. Remove the standing water. I used a wet vac to remove the standing water from the bottom of the machine, but you can scoop it out also. 4. Tilt the locking clamp (tilt left) to the side. (this is a metal wire covering the white plastic valve. This valve is to the right of the triple filter basket.) 5. Pull out the non-return valve and rise will under running water. You may have to wiggle the valve a little. Pull straight up and out. 6. The drain pump is beneath the non-return valve. (it has a little plastic propeller, like a paddle wheel, inside) 7. Spin the propeller several times in both directions to make sure it's clear. ( I used the shop vac with a small hose attachment to clear the drain above the propeller compartment) 8. Carefully refit the non-return valve and secure it with the locking clamp. 9. Refit and lock the filter in place.
I haven't had a problem since and my dished are much cleaner- The problem must have been coming on for a long time.
Hope this helps,
Posted on Oct 08, 2008
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
What does it mean when during a wash, it stops and a H and then an F flashes? Thanks,
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Jan 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer giving error code FH begins cycle filling with water then stops and only get humming and no more water and finally the error code
Or
Dec 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a FH that comes on the display any ideas? please It washes to a certain point then stops showing the display but if i then put it on drain it empties ok
Might want to start with this.
Or
  • Verify CCU operatiion
Dec 20, 2010 | Whirlpool AWM8103/1 Front Load Washer
Washing machine stopped, it is beeping and
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore 44921 Front Load Washer
I just have an F flashing and then an H-- washer starts to run and then stops after filling
CODE FH
If after 30 seconds the control does not detect water entering machine,
the valves will be turned off and the error code will be displayed. Or If
sensor has detected 10.5 gallons of water passing through it, but has
Potential Causes
_ If there is no water in the unit:
the way.
inlet valves.
Verify inlet valve operation.
_ If there is water in the unit:
Verify Drain pump operation.
Verify that the Pressure Switch Hose is in good condition and
properly connected to Tub and Pressure switch.
_ Verify there is not a siphon problem.
_ Verify wire harness connections to; Inlet Valves, Pressure Switch,
Drain Pump, Flow Meter, and Central Control Unit (CCU).
_ Check all hoses for possible leaks.
_ Verify pressure switch operation.
_ Verify flow meter operation.
_ Verify CCU operation.
Apr 23, 2010 | Kenmore Elite 45986 Front Load Washer
Letters H & F start flashing mid cycle which stops the cycle
error code  -----  F/H ----------- reason ----------- No water detected entering machine or Pressure switch trip not detected.
Or
solution to resolve  -----------   Press PAUSE/CANCEL twice to clear the display.
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Mar 14, 2009 | KitchenAid Washing Machines
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code HF
Or
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washerf
Failure
Code
Condition
Check/Repair
F/H
Or
  • Verify CCU operational
Nov 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 4t
This what to check for F/H code from repair manual.
If the water is coming into machine, make sure drain hose is only sticking into drain pipe about 6 inches. Post back if you have any questions.
Or
Potential Causes
Pressure switch
Nov 07, 2007 | Kenmore Elite HE4 Electric Dryer
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
103 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
