Question about Gateway GT5082 PC Desktop
I started having issues with my GT5082 shortly after installing SP3 from microsoft. My video would go wacky and then return to normal. Now, my PC is dead. It will power-on but will not get past POST. I have no beeps, no video. I have checked the power supply outputs, reset the 4 RAM cards a few times, reseated the CPU and checked all the cables. I see no caps being bad on the MOB or inside the PS. How do I know what is bad without any BIOS codes? I'd appreciate any insight you may have.
  • ds41439 Jun 29, 2009
    Thanks Baker, but I think I'm beyond an XP disk. I have no HD output, no video output, no CD output. If it happened to be an installation issue with SP3, I would think the crash would have been more immediate and not gradual as it were. It's leaning more towards a hardware failure; MOB or CPU. I can't get a POST code so I was hoping someone with a good bit of hardware troublehooting experience could identify the culprit by symptoms alone. Or at least point me in the right direction. I appreciate your time though.
  • 32 Answers
The installation of SP3 didn't finalize or it had complications. Your computer is "freaking out" because your missing things that windows needs to boot. If you have your XP disc insert it and reinstall or Fix the missing pieces. It will automatically find it for you
Posted on Jun 28, 2009
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Gateway gt5082: usb not working, on the motherboard and front. i have installed a new hd and installed the new recover gateway cd that came w/the computer. still nothing.
If you reinstalled operating system then it means it's a hardware issue. You'll have to check the internal connections from motherboard to front panel. I'd also poke around the bios setup page to see if it was accidentally turned off. It's not likely the case, but it's always best to check.
Hope this tidbit of info gets you going. Let me know if you get stuck or have a specific follow up question.
Feb 08, 2011 | Gateway GT5082 PC Desktop
Am trying to download Office 2010,but the comp. tells me I am not running the XP sp3. How do I fix this ? My comp. does automatic updates.
Manually install the updates by going to the Microsoft Update website. Click start, select all programs, and select Windows update. Allow the updates to download and install. Continue to update until all have been installed. You may have to return to the update page several times before Service Pack 3 can be downloaded and installed.
Jan 26, 2011 | Microsoft Windows XP Professional SP3 Full...
Gateway GT5082 will not load. It powers up, power on light is lit, harddrive and dvd drive flash at the same time. CPU fan runs continous nothing loads.
Try starting in SAFE mode first by pressing F8 repeatedly as you poweq up and see if it wil start in safe mode.
If so remove any recently installed hardware or programs and then re-start
Let me know how you get on
Aug 20, 2010 | Gateway GT5082 PC Desktop
Service pack 2 for xp crashes the system
Access http://www.microsoft.com/downloads
and download XP Service Pack 3, and install it.
It is *NOT* necessary to install SP2 _before_ installing SP3.
After installing, run Windows Update (for another 80+ updates issued since SP3 was issued).
Dec 26, 2009 | E-Machines M2350 Notebook
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
Windows XP Pro SP3 will not boot normal mode
This may be because you have the wrong drivers installed- i reccomend starting your computer up in safe mode and using system restore go back to a past restore point before upgrading to SP3
then update your drivers before upgrading to SP3
i reccomend drivermax.com to update drivers.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Microsoft Windows XP Professional SP3 Full...
SP3 nightmare install
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07159&lc=en&dlc=en&cc=us&product=1127351&rule=24868&lang=en#
This should help you also
On March 6, 2008 Microsoft released Service Pack 3 (SP3) for Windows XP. Service Pack 3 contains all of the important Windows updates from previous service packs as well as additional updates that were released after Service Pack 2. To install Windows XP Service Pack 3 from the Internet on a home desktop computer use the Windows Update feature. CAUTION: If you have an HP Pavilion, HP Media Center or Compaq Presario desktop computer that has an AMD processor, your PC might encounter a startup problem after installing SP3 (or SP3 will not download from Windows Update). Before attempting to install SP3, install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors . For more information, the following support articles from the Microsoft Web site can help: 322389 - How to obtain the latest Windows XP service pack (in English) 936929 - Release notes for Windows XP Service Pack 3 (in English) NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jan 25, 2009 | HP Compaq Presario SR1620NX...
Xp sp3 wireless not working properly
You can try this WPA patch for SP3
http://www.microsoft.com/downloads/details.aspx?FamilyId=009D8425-CE2B-47A4-ABEC-274845DC9E91&displaylang=en
If this does not work you can revert back to SP2 by
Click start then control panel then go to add/remove programs. Look for Service Pack 3 and remove
If that does not work you can also do a system restore by
Click start then run then type in msconfig
Click on launch system restore.
Restore to a date before your SP3 update.
Note: All other installations after this date will be lost
Your files will NOT be lost
Aug 29, 2008 | Microsoft Windows XP Professional With...
Not Installing XP SP3 Updates Given By Microsoft KB 936929.
if you don't want to install those updates you should have switch off your automatic updates. the problem is the your computer might not be compaitble with the update which was sent to you.XP SP3 have a higher system and hardware requirements than xp sp2. in order to resolve your problem you need to run your xp sp2 and press repair instead of format in this way it can return to your original system. you can also try the system restore press the start, all programs look for the system tools then system restore check what date you installed this sp3 then select the day before you installed this in order for you to return to your original operating system. hoping that this will help you, expecting your positive response.
Dec 14, 2007 | Microsoft Windows XP Professional With...
Gateway GT5082 PC Desktop Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
