Question about RIM BlackBerry Pearl 8100
Pearl ball will not move up and down. Can it be
Pearl ball will not move up and down. Can it be fixed?
I cannot go down on the main menu. I can use the keyboard to fight with messages but having trouble getting to pictures to remove from phone.
My blackberry does this all the time. I keep a supply of alcohol swabs available and rub it over the ball for about a minute and it always works. They seem to get dirty easily and need to be cleaned fairly often.
Posted on Jun 28, 2009
My blackberry ball won't move how can i fix it
u can go on ebay and buy a new trackball for ur phone that is what I did and it works great..
Jan 04, 2010 | RIM BlackBerry Pearl 8100
Rollerball will not go up it goes left and right and down
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Pearl 8100
Roller ball on blackberry won't work
Was it Like it when you bought it?? If not, then its probably broken.. it happens a lot with rollerballs.. if you take it back to the shop you bought it from they will probably send it away to be fixed.
Sep 05, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl wont turn on....
Try taking the battery out for a minute then putting it back in and see if it will turn on. Otherwise the display may be broken, did it get dropped?
Aug 29, 2009 | RIM BlackBerry Pearl 8100
Trackball gets stuck on BB 8100 Pearl
You can actually pop the trackball out and clean it and the sensors. remove (gently) the silver ring around the ball. if you break it you can buy new ones cheap.. it just snaps in to place. then the ball will fall out and you can take a q-tip and rubbing alcohol and clean it.
Jul 21, 2009 | RIM BlackBerry Pearl 8100
8100 rollerball wont scroll down
sounds like the ball is gummed up.. there are several sites that will show, with pics, how to remove the ball assembly and tear it apart to clean it... but be careful.. it is not as easy as it looks.. i ended up buying a new ball off of ebay for under $12 shipped.. so i suggest that route
Dec 31, 2008 | RIM BlackBerry Pearl Smartphone
Roller ball on my Blackberry Pearl will not work.
I had the same thing happen. Tried everything to fix it. Finally, after a couple of hours of troubleshooting, I just gave up and went and put in on the charger. When I did that it fixed it. Have no clue why but it did.
Nov 20, 2008 | RIM BlackBerry Pearl 8100
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
satan phone? get a waranty replacement
Apr 07, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
192 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
