How do I get to the coil in my air conditioner?
    Novelist:
  • 166 Answers
To get access to your A/C coils, follow step one of this handyman article guide on how to effectively clearn your A/C to make it cool better:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
This should help resolve your question.
Brad
Posted on Jun 28, 2009
Frost and ice forming on coils
Check the air filter...or the coils are dirty.. not getting enough air through the coils...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 08, 2010 | LG LWHD1807HR Thru-Wall/Window Air...
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
heatman101
Sep 03, 2010 | Fedders D Chassis A6D24E7A Air Conditioner
Dirty coil
You can buy some coil cleaner at a heating and air supply or maybe Lowe's Home Improvement. The coil needs to be clean for the unit to work properly.
Jul 16, 2010 | GE AJCQ08ACB Air Conditioner
My air conditioner keeps freezing up
Probably 75 to 80 percent of all air conditioner service calls are repaired by simply cleaning the coil fins. If it is a window air conditioner, unplug it from the wall, remove the front cover and brush the coil fins using an up and down motion. Next go outside and brush the outside coil the same way. Then blow through it with water. Too much water pressure can also bend the cooling fins. The inside coil if extremely plugged up can be washed also but it will be necessary to remove it from the window to do so. If this doesn't solve your problem, chances are that it is either low on freon or the compressor is weak. It may be time to look for a new one. I hope this helps
Jul 04, 2010 | GE AJCQ08ACB Air Conditioner
My samsung portable window air conditioner is 4 years old and it does not blow cold air. Like at 66 degrees it is not that cold why
It is either low on freon,or,the unit needs to be removed,and cleaned,especially the coils,the condenser coils,and the evaporator coils,be careful not to bend fins on coils,use a water hose,and clean the inside of the unit out,clean off coils real good,see if this is the problem,it always helps.If this was helpful,please rate,and thank you,
Jun 28, 2010 | Samsung AW1203B Air Conditioner
Does not cool coils frost up in front
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
May 28, 2010 | Fedders X Chassis A6X06F2A Air Conditioner
I have a slant coil in my A/C unit. Is it normal for the coils to frost up and sweat?
hello,this happened simply because the conditioning system hasgone below 32 degrees f.and if this has happened you will experience frost in the coil area.this as a result means the air conditioner does not get enough air from the fan,so therefore,you will need to service the air conditioner and also clean the coil properly.
wish you good luck
take care.
Apr 21, 2010 | Carrier Heating & Cooling
Can you please give me 5 problems and 5 solutions on condenser for a samsung air conditioner
Most of the problems that arise with a window A.C. unit are from the "front", and "rear" coils ,or the filter at front are dirty. When the unit is on,the air is sucked in at both coils,and should be cleaned yearly. The front coil,and the filter are easy to clean,but the rear coil can be difficult.After checking the front, with the on cool, go outside and put your hand at the rear coil and feel if there is warm air blowing out.If not, your rear coil is probably clogged.Note:Do Not use high pressure hose to clean the coils,please.
Feb 17, 2010 | Samsung AW0603B Air Conditioner
Window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Aug 24, 2008 | GE APN10AA Portable Air Conditioner
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
