Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
I removed all the connections on my 3210 emachines motherboard now i realise that i dont know how to re-connect the power switch wires,there are 3 altogether, does anyone know where i can get a diagram? or what order they go back.
  • 180 Answers
You can connect the power connector to the corresponding sockets. It wont make any problem if it is changed one another. Only thing you have to connect in the correct position.
Posted on Jun 28, 2009
    Novelist:
  • 186 Answers
If I'm not mistaken, you are talking about the connectors which go on the Motherboard header. There are ussually 2 but they seperate them with a blank space. I may be wrong with what you are asking, but if you put pwr+ on one of the header pins ( having a manual to tell you which is + is helpful, but not necessary. Connect the pwr - to the other pin next to the +. You should now be able to flip the switch and turn it on. I'm sorry if I misunderstood what you were looking for.
Posted on Jun 29, 2009
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
is the Front Panel header.
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
I have a T5026 EMachine won't power up. Green light on motherboard is on , could it be the switch , tried putting a new power supply box in it.
to see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
Nov 06, 2010 | E-Machines Emachine T5026 power supply **...
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Install a AU31 E machine Motherboard I need to know exactly where each of the tiny power wires go on the motherboard that controls the power.
from the power supply there's a wires with 16 or more pins / connected as 1. insert the in corresponding socket on the motherboard. on the casing there's a wire that has a label of power or power switch. insert that in the motherboard with an indicator power (pins like)
Jun 02, 2010 | E-Machines eMachines Refurbished EMA...
Wiring diagram for emachine pc 3210 as the wires have been romoved and i dont know where they go back???
Are you referring to the Power Switch, LEDs and such? If so they might be somewhat labeled on the motherboard itself. Or you can try emachines website they should have a manual available I would think.
Sep 30, 2009 | Computers & Internet
Emachines computer not turning on
IS ALL CONNECTION CORRECT, TYPE IN
EMACHINE COMPUTER DOWNLOAD DRIVES
ENTER
SEE IF ANY OF THIS INFO CAN HELP YOU
THE MAIN SWITCH FROM THE PANEL ON THE FRONT OF YOUR COMPUTER DIDNT MATCH YOUR NEW MOTHERBOARD CONFIGURATION
START BY REMOVING ALL WIRES AND CONNECTORS EXCEPT POWER ONE, SEE IF SYSTEMS TURNS ON, THE POWER SWITCH MAYBE THE PROBLEM, RESET SWITCH, ANY EXTRA CARD YOU PLUG INTO YOU MOTHER BOARD
*********REMOVE ANYADD ON CARD ANY ADAPTER DEVICE ALSO,
ADD ONE WIRE AT A TIME UNTIL ALL WIRES ARE CONNECTED
CANDYMANCANDY
Jan 27, 2009 | E-Machines (308714) Motherboard
Problem with power connections on emachine T2596
Take a peek at this link,
http://www.duxcw.com/faq/mb/frontpanel.htm
it may assist you in your problem
Dec 17, 2008 | eMachines Computers & Internet
EMachine no power
Ok for a start the power switch is not green and white that is the power led, you need to look for a red and black wire normally marked on the connector and motherboard as pwrsw or pswitch.
if you believe it to be the switch unplug the connector and jump the connection on the motherboard using the reset switch or a jumper, or not recommended but have done this myself many times using a flat blade screw driver very carefully and touch the 2 pins to complete the circuit.
if it doesnt power on then its more than likely it is the power supply but the motherboard being faulty could also cause this to happen.
the problem i have found with emachines is that its difficult to get replacement power supplys
Nov 30, 2007 | E-Machines eMachines Desktop PC
Power button wiring help
Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 15, 2007 | ASUS A8V Deluxe Motherboard
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
300 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
