Question about Alpine Car Audio & Video
I have an alpine IDA-X305. When I plug my Ipod into it, it plays the audio from the Ipod, but every 16 seconds it has a maybe half second pause in the audio (goes silent) then comes back to normal. It is mostly random, and seems to be stuck in this mode. I believe it might be pulling data or the bluetooth setup with my parrot handsfree? dont know, just would like it to play with out the pause. The ipod plays fine normally when it is not connected to the headunit.
    Genius:
  • 1,269 Answers
Try to turn off bluetooth handsfree first on your alpine. Now, try to disable the random song feature on your ipod. If that didn't solve it, try to use the bluetooth handsfree feature and not the direct connection.
Posted on Jun 27, 2009
Is there an update for the alpine ida-x300 to run the new generation ipods ? It states, on the connected ipod / iphone, that it will not charge.
If you get the ALPINE KCX-422TR or search ebay for "12V TO 5V CHARGING FOR iPOD iPHONE" you can get a fix for your iphone cable. Basically the new iphone/ipods use 5v not 12v like the older models.
Feb 12, 2011 | Alpine IDA-X300 Car CD/ MP3 Player
When I plug in my ipod into the the AIpine get an
Are you using the KCE-422i cable included with the unit? The iPod will not work plugged into the USB port with the factory Apple cable. You need to use the silly Alpine cable.
May 31, 2010 | Alpine IDA-X300 Car CD/ MP3 Player
Hi i plug my ipod in and the songs wont play i try to press the play/pause button but no luck the radio still works n the unit picks up the ipod help plz
you might have to reset your ipod itself. press the center circle and menu button at the same time until the apple shows up then plug back into your alpine. hope this works
Dec 19, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
My ida-x100 doesnt recognise my ipod when using the apple usb cable
I have a similar problem. The original Alpine USB cable fell apart on me and I began receiving an error message. "No, biggie," I thought. "I have plenty of iPod USB cables." But I get an error message with each one, as well as an error message with every iPod I've tried. Apparently the IDA-X100 will only read iPods if you use an original Alpine USB cable.
Sep 05, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
IPOD is hanging but can't be reset.
i would try reformatting your ipod to factory specs (can be easily done with itunes following the information provided at mac.com)
to reset the ipod, turn it off, then on -- then hold down the 'menu' key while pressing the center 'click' key until you get the apple logo. this just may solve the problem.
Apr 25, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Aipine ida x 100,usb device error
Are you using the original Alpine iPod USB cable? If not, that could be the problem. The iDA-X100 will only read iPods using the Alpine cable. Otherwise, you get a "USB Device Error."
Mar 08, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
Alpine ida-x001 volume is low even if stereo is turned all the way up only when ipod is plugged in on ipod setting.Radio (AM/FM) is normal volume (louder)..How can I fix this?
Most newer car receivers have a feature named something like "level balancing" in which you can adjust the relative loudness of each input (Tuner, CD, AUX, IPOD). Check you owner's manual for a similar function.
Also, are you or can you turn the level of the ipod itself up a bit?
Mar 07, 2009 | Alpine iDA-X001 CD Player
Alpine IDA-X300 not playing mp3
try recording a cd as a wma instead of mp3 format. i had this problem before and that worked for me
Jan 11, 2009 | Car Audio & Video
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Sub Shuts off after only being up half volume
try to check your speakers. check the pigtail, maybe it is disconnecting from the cone or from the connector. then after that, resolder it.
if still you h ave the problem we will proccede to the next step. let me know...
Nov 05, 2007 | Alpine MRP-M350 Car Audio Amplifier
Car Audio & Video Logo
66 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
