Question about Dell W4201C 42 in. Plasma HDTV
My 42" plasma tv screen went black but there is still audo
2 weeks ago half the screen was black on and off now it is completly black
    President:
  • 1,077 Answers
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
I have dell w4201chd and the screen went blank no pitcure or sound,I have power to the lcd lights on motherborad can you help me?
Posted on Aug 09, 2010
4 Suggested Answers
  • 90 Answers
SOURCE: black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Posted on Jan 30, 2009
Senco
  • 51 Answers
SOURCE: 42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs
Posted on Aug 28, 2009
paul4265
  • 592 Answers
SOURCE: Dell 4201C Plasma 42" -
Hi, Mary.
This sounds to me like it is a bulb issue, and not something worse, like failed capacitors.
If that is the case, then yes, it is worth repairing it.
You need to get the old bulb out, either by removing it yourself, or by having someone take it out for you, and the take the old bulb to Fry's or BestBuy.
They both keep tv projection bulbs for flat screen tv's in stock.
I hope that I've helped you understand what is going on, and that it helped.
Have a nice day, and good luck.
Posted on Mar 14, 2011
Testimonial: "Thanks so much for your help. We will give that a try."
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Samsung plasma TV, half screen is blacked out
Well, as per my last posting, I thought I would share. The problem of the bottom half of my 42 inch Samsung Plasma blacked out - meant a trip to the local TV repair shop. I have to say, they were great. I took it in and they were able to fix it after replacing a part - had my TV back in about a week. Cost was approx. $300. This was well worth it, considering how much I had paid for this TV only a few years ago. I had the repair done last month and so far, it's been great. Sorry, but I can't remember the name of the part.
Aug 10, 2008 | Televison & Video
Screen went half black then full black
Sounds like a common voltage adjustment with samsung plasmas,I would call a service center these are things if you dont have experience you shouldnt attempt yourself
Apr 26, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Half Screen went black
Try to replace the Logic board.
Dec 17, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Picture problem, half screen blank
On a plasma there are 2 buffer boards, upper and lower, it all depends which half of the screen is on as to which buffer to replace, the buffer boards are located usually on the left hand side if you have the back off the unit. You maybe able to reseat the ribbon cables and get the video back up
Feb 17, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Dell W4201C 42 in. Plasma HDTV Logo
1,976 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
