Question about KDS Valiant 6380iPTD-01 Notebook
I have a Vaillant boiler Turbo Max VUW 242/1E, central heating is working but no hot water
How do i work the timer switch on a vaillant turbo max vuw 242 boiler it would be nice to wake up with the heating on thanks
Posted on Jan 06, 2010
  • a4049
    a4049 Nov 29, 2013
    I have a 2001 model VUW 242 E.
  • a4049
    a4049 Nov 29, 2013
    The segmented mechanical time switch on it has four segments per hour around the ring and a little three-way "on-timer-off" tab at the top left. If you have one of these then check that your three-way tab is on the middle setting "timer" and that some segments of the wheel are in or out so that you can see it switching when the wheel rotates to one of your "on" times. Test by turning the wheel into an "on" segment. Burner ignition lamp, "radiator" demand lamp and "flame" lamp ON within 60 seconds is "pass". Central heating not starting in 60 seconds is "fail". Rotate the wheel (it clicks a bit) so that the present time is matching your clocks.
It's not the valve itself, it's the switch at the end, but you have to buy the whole diverter to get the switch, just another way to con us out of money, Vaillant are a bunch of thieves.
Posted on Oct 15, 2009
  • a4049
    a4049 Nov 29, 2013
    I got a gas safe fitter to put in a new Diverter assembly for that in Feb 2013. Around Sept 2013, it ceased to switch on demand for hot water. Last week the gas-safe plumber said that the diverter is faulty and needs replacement. Perhaps it is something else?
    Scholar:
  • 83 Answers
You have a faulty diverter valve, this is a fiddly job, you need to call in a 'Gas Safe' engineer to diagnose and replace this
I hope this helps
Steve
Posted on Jul 10, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Vaillant boiler
diaphram leaking or poor electrical contacts in microswitch
Posted on Jan 06, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
I have a Vaillant ecoTech central heating boiler which has stopped working & is showing fault code F.76 Anyone know what this means please? Thanks
f76 over heat protection triggerd on heat ecxchanger , check water leval of just google vaillant fault codes
Jun 03, 2010 | Heating & Cooling
I need to power flash a vaillant boiler. can you please help. water goes hold and cold, sometime the heating stop but the water works and vice versa. i was told by an engineering that it needs power...
Hi
Although not a PC problem, i have had this same issue on my Vaillant Boiler, the problem you are describing is not a power flush problem, you need to clean out your exisiting diverter valve or purchase a new one
The diverter valve is repsonsible for either providing hot water or providing hot water to the central heating, when this valve gets stuck in between the symptoms you have described above occur
I would also not recommned that you do a power flush yourslef as you may end up damaging the boiler and its pump
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Boiler problem
check the air flow,venturi in fan and pressure switch
May 16, 2009 | Sun Time NCAA Purdue Boilermakers...
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
KDS Valiant 6380iPTD-01 Notebook Logo
1,933 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
